Spilled Orange juice on laptop help!!!!!!!!
Discussion in 'Sager and Clevo' started by Lavitz, May 8, 2009.
  1. Lavitz
    Lavitz Notebook Evangelist
    Okay, so far i cleaned the keys with compressed air can. Windex(glass cleaner) and vacumed up the juice.Now i found Lysol and im wondering if i can spray it on the laptop without damaging any hardware. Any help is highly appreciated. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. TabbedOut
    TabbedOut Notebook Evangelist
  3. Shyster1
    Shyster1 Notebook Nobel Laureate
    Why on Earth would you want to spray lysol on your system?
  4. Lavitz
    the removing procedure would be different for my notebook,any idea if there tutorial for mine. Also at the moment I am just pulling keyouts and cleaning them.
    Lysol why? Well if laptops have some sort of seal then the fluid shouldn't go through and once it sits for like 1 min i can suck it out with an vaccum.
  5. Kdawgca
    Kdawgca rotaredoM repudrepuS RBN
  6. TabbedOut
    The keyboard removal procedure would certainly be different, HOWEVER the point I was trying to make was that if you can remove the keyboard I believe that the best way to clean it would be to rinse it off. The Lysol will do little to remove the sugar that will create the subsequent stickiness. Also I have some doubts as to how effective a vacuum would be at removing Lysol that you have sprayed. Finally, I'm not sure that you could spray on enough of any liquid to effectively remove the offending fluid without at the same time soaking the underlying electronics.
  7. TabbedOut
    Yeah, and a little bit of this too.
  8. alexka
    alexka Company Representative
    Power down notebook and remove battery
    Open up notebook (DO NOT USE LYSOL OR ANY OTHER SOLVENT)
    Check for OJ residue and use denatured alcohol to clean up
    Allow everything to dry before powering up
  9. Lavitz
    ^^ Those are all well made points. Well I don't want to personally take the keyboard out quite yet. Do you think i could do it if notice the the key are stating to stick? Or would it be too late?.I kinda want open the keyboard to me last resort.
  10. TabbedOut
    It is INFINITELY easier to fix the problem before the keys start to stick. If you spilled juice you should probably assume that they will.
