Spare parts for CLEVO W370ET?
Discussion in 'Sager and Clevo' started by coldpumpkin, Jun 14, 2018.
  1. coldpumpkin
    coldpumpkin Newbie
    Does anyone know where I can get spare parts for CLEVO W370ET? I'm located in Europe.
    I specifically need the top cover (behind LCD) and the main cover (the one with keyboard etc).
  2. Danishblunt
    Danishblunt Guest
    Write an email to clevo center germany or UK.
  3. coldpumpkin
    coldpumpkin Newbie
    You mean to a reseller?
  4. Danishblunt
    Danishblunt Guest
  5. coldpumpkin
    coldpumpkin Newbie
  6. Prostar Computer
    Golden Star service centers don't usually work with end-users directly, but it's worth a shot.
    You can try independent sellers (eBay, Aliexpress, etc.) for parts or complete systems being sold for parts, might have more luck there.
  7. Danishblunt
    Danishblunt Guest
    Both UK and Germany clevo center were willing to give me a deal on a mainboard. So they do work with normal users.
  8. XMG
    XMG Company Representative
    http://www.clevo.com.tw/clevo_contact.asp?lang=en
    All the service centers are here. As @Danishblunt says, the UK and DE ones will definitely sell direct to members of the public, but you need to be specific about what parts you need. You're after an a-cover and c-cover, but sometimes if you don't specify that you need the fingerpring reader of touchpad for example they'll send you a c-cover without touchpad. Best to check the service manual and check the exact part numbers to be on the safe side. The service centers will also generally do the repair for you if you need.
  9. Danishblunt
    Danishblunt Guest
    Can confirm this, they are very clear about wanting partnumbers etc. They will likely ask you to provide it.
  10. coldpumpkin
    coldpumpkin Newbie
    Yes, goldenstar DE said they no longer have parts for my model. I'll try with the UK one. Thanks all for the help.
