Sound quality in CF-W8
Discussion in 'Panasonic' started by theoak2, Mar 27, 2011.
  1. theoak2
    theoak2 Notebook Evangelist
    Am I the only one who thinks the speakers in the W8 are really bad? My sound is very low volume, and vibrates/rattles a lot. Does anyone else who has this model think the speakers are really bad (even for a laptop)? Or have I got defective speakers?
  2. cyrilng
    cyrilng Notebook Geek
    Generally speaking the single downward-firing mono speaker in the W8 is not going to impress anyone. I turned mine all the way up but didn't detect any rattling although there was a fair amount of vibration.
  3. ToughNut
    ToughNut Notebook Evangelist
    MONO??!! Duh... for a laptop with those specs, I would have expected stereo, even if it isn't well defined stereo for that matter. What was Panny thinking??!!
  4. Alex
    Alex Super Moderator
    My major complaint with my CF-F8 was the sound quality
    You sacrifice sound quality for portability
  5. Regnad Kcin
    Regnad Kcin Notebook Evangelist
    Stereo, mono, does it make a difference on most laptops? Really I found the CF-29's mono speaker to be better than many laptops because it simply worked better. One good speaker is worth more than two bad ones.
    The W8 isn't good but really, it wasn't much worse than the lousy sound on my Dell M4400 and is much better than my Toshiba netbook.
  6. cyrilng
    The W8 is a business-class laptop so hi-fi quality stereo sound was not a priority I guess.
  7. TopCop1988
    TopCop1988 Toughbook Aficionado
    Now you know what that "Headphone Jack" (Item "I", Page 12) on the front is for. ;)
  8. ToughNut
    urm... DUAL mono?? :D
  9. TopCop1988
    If it's not stereo, why <:confused:> do the Operating Instructions say "Use a condenser-stereo microphone." (Page 39, Footnote #22)? ;) :rolleyes:
  10. Shawn
    It could have mono output to the speaker and have stereo input via the microphone.
