Sound Blaster Recon3Di Defect Discussion Thread - Questions/Solutions Here [M18x R2, M17x R4 Audio]
Discussion in 'Alienware' started by Peter, Oct 1, 2012.
  1. j95
    j95 Notebook Deity
    Left speaker mid-high frequency distortion, including previous versions, but I'm not sure what caused this...if you have spare speakers try to replicate M18xR2 issue...besides drivers, Creative included all necessary IVY AW installation files...possible fixes? CPL "Device not supported" is intentional...request.
  2. Mr. Fox
    It sounds good on this M18xR2 using internal speakers. No distortion and I am not finding any "Device not Supported" errors. Are you encountering that with external speakers and headphones?
  3. j95
    j95 Notebook Deity
    No errors, I meant installing without any modding.
    Mr. Fox likes this.
  4. j95
    j95 Notebook Deity
    @Mr. Fox updated Recon3Di Win7 version Sound_Blaster_Recon3Di_Win7_M17xR4_M18xR2.7z
    v1.01.07 fixed the sound suddenly disappearing? Sound quality is better than any previous driver package, I'm currently testing the right speaker, probably not related so I'll re-upload two versions for each laptop.
    Mr. Fox likes this.
  5. Mr. Fox
    Thank you, bro. I already packed up the M18xR2 for storage last night, but I will get it out again later today and apply the second driver mod you attached today. Great work, as usual. And, yes... I have never had any more issues with disappearing sound since I started using the newer drivers mentioned earlier in this thread.
    Did you happen to see the M18xR2 BIOS mods/updates that @Swick1981 and @Raidriar have been doing? The mods work awesome. In theory, the same updates should be totally doable for your M17xR4.
    j95 likes this.
  6. j95
    j95 Notebook Deity
    Update:
    Windows 10/8.1: Sound_Blaster_Recon3Di_v1.01.09_Win10_8.1_M17xR4_M18xR2.7z
    Windows 7: Sound_Blaster_Recon3Di_Win7_M17xR4_M18xR2.7z
  7. Speedster159
    Speedster159 Notebook Enthusiast
    Uhh... https://virustotal.com/en/file/3368...4cabaadac00eb2fcd83e5075/analysis/1462483044/
    You sure it's clean?
  8. Raidriar
    Raidriar ლ(ಠ益ಠლ)
  9. funkmasterta
    funkmasterta Notebook Evangelist
  10. paradigm
    paradigm Notebook Deity
    Nopes, no issues whatsoever, however I can say that THX may not be working but it's stable
