Sound blaster error
Discussion in 'Sager and Clevo' started by opayaa, Mar 12, 2018.
  1. opayaa
    opayaa Notebook Enthusiast
    Hello. Since yesterday everytime i open SB software i get this error and can't find any solution on google. https://imgur.com/OSOUyoH
    Also, i think the sound on headphones went a litle bit weird..
    Any help? Thank you
  2. Meaker@Sager
    What is you if default audio device? Did you make any changes at all?
  3. opayaa
    What u mean? Sorry im a completely noob. I have realtek drivers installed (6.0.1.7930) and SB and never had problems till yesterday when the sound went weird, i did not changed anything before. However, i think the sound is good now but i still get the error on SB, and when i try to uninstall SB i get another error "impossible to locate the specified module".
    What can i do?
  4. Meaker@Sager
    Some life skills for the future, if someone asks a question then pick out some key words.
    I asked you:
    What is your default audio device?
    Pop that into Google and we get:
    https://www.google.co.uk/search?q=d...-android-sonymobile&sourceid=chrome-mobile&ie
    With the top result being a guide with pictures.
    This will let you get the information requested and we can rule out another audio device being default which will disable the creative controls.
  5. opayaa
  6. Prostar Computer
    We ran into this awhile back during a transition of driver updates and updates to the SB software. Which make and model is your laptop?
  7. Meaker@Sager
    opayaa likes this.
  8. opayaa
    My laptop is P650RP6-G. I think i had this issue earlier when i bought my pc, but i re-installed OS like 2 or 3 times because i was facing some bsod and it was solved.
    I have SB software installed just to improve the sound quality, i never use effects or custom profiles, and the sound is good now.. not weird anymore. But i sitll get the error when i open the software, so something is wrong..
  9. aIex
    aIex Notebook Consultant
    Try Equalizer APO + Peace GUI.
  10. opayaa
    I dont need any other software.. the sound is working great and i always try to keep my pc as clean as possible. I just would like to know why i get this error on SB, i can't even uninstall it..
