Sony VPCE series ACPI problem
Discussion in 'VAIO / Sony' started by Maho347, May 31, 2017.
Tags:
  1. Maho347
    Maho347 Newbie
    Model: Sony VAIO VPCEC 1M1E PCG-91112M
    Motherboard foxconn 1P-009CJ00-8011 MBX-225 M980
    BIOS : R0300Y8.ROM
    BIOS brand : AMI aptio V4 ?, BIOS UEFI compatible.
    Hi, first sorry for my bad english, I'm French.
    I recently buyed for parts a laptop without hard drive. When I try to install windows the laptop stuck on multiple step. (I can share videos)
    -Windows 10 : directly after "press a key to boot from usb" when the windows logo appears before the balls rotation.
    -Windows 10 pré-installed from another computer : same stuck on logo.
    -Windows 7 : after loading files, the laptop screen go dark.
    -Windows 7 safe mode : stuck at pnp.sys or disk.sys
    - Xp : Dark screen after enumerating all drivers
    - Xp acpi=off : bluescreen
    -Ubuntu : installation complete only if acpi=off and works flawless without extra fn key fonctions else with acpi= on verbose stuck at "Freeing SMP alternatives memory : 32K"
    All components seems to be ok, I tried liveXP or windows to go key made with rufus. 2 another RAM stick.
    Pc-Check V6.21 Quality Assurance Report
    Machine Configuration
    Machine Name ................ TEST
    System ...................... Manufacturer: Sony Corporation*
    Product: VPCEC1M1E*
    Version: C604A9L3*
    Serial: 27523660-5002145*
    Motherboard ................. Manufacturer: Sony Corporation*
    Product: VAIO*
    Version: N/A*
    Serial: C604A9L3*
    BIOS ........................ Vendor: AMI (American Megatrends Inc.*)
    Release: 09/23/09 (07/20/2010*)
    Processor ................... Type: Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz
    Speed: 2128.10 MHz (2.13GHz*)
    Multi-Core: Present, 8 way
    Hyper-Threading: Present, 2 way
    Total Logical Processors: 16
    External Clock: 133MHz*
    Memory ...................... Installed: 2GB*
    Available: 1.92GB
    Device Type: Unrecognised*
    Memory Bus .................. 64 bit
    Cache (per core) ............ Level 1: 32+32 KB (128KB*)
    Level 2: 256KB (512KB*)
    Level 3: 3MB (Shared) (3MB*)
    Drives (fixed media) ........ BIOS (320.07GB)
    Video ....................... ATI ATOMBIOS (16384 KB)
    Modem ....................... Unknown (Vendor 8086H Device 3B64H)
    Network ..................... Unknown (Vendor 168CH Device 002BH)
    Buses ....................... PCI, AGP, ISA/LPC, USB
    Information marked with a * is provided by the BIOS and may be inaccurate.
    Signature: ______________________________
    Tester Name: TEST
    Serial No.: TEST
    31/05/2017 09:46 Activation Name: Micro_Center Page 1 of 5
    Ports ....................... Parallel
    Tester Name: TEST
    Serial No.: TEST
    31/05/2017 09:46 Activation Name: Micro_Center Page 2 of 5
    Quality Assurance Testing Results
    Component Test Description
    CPU 1 CPU 2 CPU 3 CPU 4
    PROCESSOR Core Processor Tests PASSED PASSED PASSED PASSED
    AMD64/Intel64 Core Tests PASSED PASSED PASSED PASSED
    Maths Co-Processor Tests PASSED PASSED PASSED PASSED
    - Pentium Class FDIV PASSED PASSED PASSED PASSED
    - Pentium Class FIST PASSED PASSED PASSED PASSED
    MMX Instruction Set PASSED PASSED PASSED PASSED
    SSE Instruction Set PASSED PASSED PASSED PASSED
    SSE2 Instruction Set PASSED PASSED PASSED PASSED
    MP Symmetry N/A PASSED PASSED PASSED
    Dev 1 Dev 2 Dev 3 Dev 4
    MEMORY Module Seating PASSED
    Inversion Tree Test PASSED
    Stride Isolation Test PASSED
    Chaotic Addressing Test PASSED
    Block Rotation Test PASSED
    Level 1 Level 2 Level 3
    CACHE MEMORY Inversion Tree Test PASSED PASSED PASSED
    Stride Isolation Test PASSED PASSED PASSED
    Chaotic Addressing Test PASSED PASSED PASSED
    Block Rotation Test PASSED PASSED PASSED
    Microtopology Test PASSED PASSED PASSED
    VIDEO MEMORY Inversion Tree Test PASSED
    MOTHERBOARD DMA Controller Tests PASSED
    System Timer Tests PASSED
    Interrupt Tests PASSED
    Keyboard Controller Tests PASSED
    PCI Bus Tests PASSED
    CMOS RAM/Clock Tests PASSED
    Tester Name: TEST
    Serial No.: TEST
    31/05/2017 09:46 Activation Name: Micro_Center Page 3 of 5
    Drive 1 Drive 2 Drive 3 Drive 4
    HARD DISK Read Test PASSED
    Read Verify Test PASSED
    Non-Destructive Write PASSED
    Mechanics Stress Test PASSED
    Internal Cache Test PASSED
    Port 1 Port 2 Port 3
    PARALLEL PORT Verify Controller *FAILED*
    Check Status Port *FAILED*
    Interrupt Test *FAILED*
    ATA Serial Controllers PASSED
    STRESS System PASSED
    - CPU PASSED PASSED PASSED PASSED
    - Hard Disk PASSED
    - Memory PASSED
    - Video PASSED
    KEYBOARD Verify Keyboard PASSED
    MOUSE Buttons PASSED
    Ballistics PASSED
    Text Mode Positioning PASSED
    Text Mode Area Redefine PASSED
    Graphics Mode Positioning PASSED
    Graphics Area Redefine PASSED
    Graphics Cursor Redefine PASSED
    AUDIO Internal Speaker Test PASSED
    Real-time PCM Test PASSED
    Streamed PCM Test PASSED
    SPDIF Run DMA Test PASSED
    Tester Name: TEST
    Serial No.: TEST
    31/05/2017 09:46 Activation Name: Micro_Center Page 4 of 5
    VIDEO Colour Purity Test PASSED
    True Colour Test PASSED
    Alignment Test PASSED
    LCD Test PASSED
    Test Card PASSED
    FIRMWARE ACPI PASSED
    I flashed the bios from Dos but maybe I don't made the flash correctly.
    Any advices is welcome even risky, this problem is for educationnal purpose :)
  2. anytimer
    anytimer Notebook Deity
    Have you tried disabling ACPI, installing Windows, and then turning on ACPI?
    Check your BIOS settings. Restore default settings. Disabling UEFI is a good idea.
    Are you using a new HDD or was it previously used in a UEFI enabled computer? Use DISKPART, etc. to clean the HDD and try again.
  3. Maho347
    Maho347 Newbie
    Hi thanks for your help, I cleaned the disk using diskpart. I got the same problem. The bios is very limited take a look on pictures. I wonder If I can find recovery data disk to restore data from factory ? or maybe unlock the bios to force ACPI off or BIOS mode only. Another things the wired network Marvell Yukon seems to be down.
  4. Maho347
    Maho347 Newbie
    I used the firmware test software to generate a report. I use ubuntu with acpi=off and apic=off.
    Code:
    646 passed, 99 failed, 8 warnings, 6 aborted, 219 skipped, 11 info only.
    Test Failure Summary
    Critical failures: 6
     klog: CRITICAL Kernel message: [    0.255070] ACPI: Interpreter disabled.
     method: Detected error 'Type' when evaluating '\_SB_.BAT0._PCL'.
     method: Detected error 'Type' when evaluating '\_SB_.ADP1._PCL'.
     method: Detected error 'Buffer limit' when evaluating '\_SB_.PCI0.GFX0.DD02._BCM'.
     method: Detected error 'Buffer limit' when evaluating '\_SB_.PCI0.PEGP.VGA_.LCD_._BCM'.
     method: Detected error 'Buffer limit' when evaluating '\_SB_.PCI0.PEG3.VGA_.LCD_._BCM'.
    High failures: 8
     syntaxcheck: Assembler error in line 2517
     syntaxcheck: Assembler error in line 8209
     power_button: Did not detect any ACPI power buttons events while waiting for power button to be pressed.
     fadt: SCI_EN bit in PM1a Control Register Block is not enabled.
     brightness: Did not detect ACPI hotkey event.
     ac_adapter: Failed to detect an ac_adapter on-line state.
     ac_adapter: Did not detect any ACPI ac-adapter events while waiting for power to be disconnected.
     ac_adapter: Did not detect any ACPI ac-adapter events while waiting for power to be re-connected.
    Medium failures: 37
     mtrr: Memory range 0x100000 to 0xdee7bfff (System RAM) has incorrect attribute Default (Uncached).
     dmicheck: String index 0x03 in table entry 'Base Board Information (Type 2)' @ 0x000ebd3f, field 'Version', offset 0x06 has a default value 'N/A' and probably has not been updated by the BIOS vendor.
     dmicheck: String index 0x05 in table entry 'Base Board Information (Type 2)' @ 0x000ebd3f, field 'Asset Tag', offset 0x08 has a default value 'N/A' and probably has not been updated by the BIOS vendor.
     dmicheck: String index 0x02 in table entry 'Chassis Information (Type 3)' @ 0x000ebd71, field 'Version', offset 0x06 has a default value 'N/A' and probably has not been updated by the BIOS vendor.
     dmicheck: String index 0x03 in table entry 'Chassis Information (Type 3)' @ 0x000ebd71, field 'Serial Number', offset 0x07 has a default value 'N/A' and probably has not been updated by the BIOS vendor.
     dmicheck: String index 0x04 in table entry 'Chassis Information (Type 3)' @ 0x000ebd71, field 'Asset Tag', offset 0x08 has a default value 'N/A' and probably has not been updated by the BIOS vendor.
     virt: Virtualization extensions supported but disabled by BIOS.
     apicedge: Non-Legacy interrupt 0 is incorrectly level triggered.
     apicedge: Non-Legacy interrupt 1 is incorrectly level triggered.
     apicedge: Non-Legacy interrupt 2 is incorrectly level triggered.
     apicedge: Non-Legacy interrupt 8 is incorrectly level triggered.
     apicedge: Non-Legacy interrupt 11 is incorrectly level triggered.
     apicedge: Non-Legacy interrupt 12 is incorrectly level triggered.
     wakealarm: Failed to trigger and fire wakealarm.
     syntaxcheck: Assembler warning in line 7299
     syntaxcheck: Assembler warning in line 7924
     syntaxcheck: Assembler warning in line 8546
     syntaxcheck: Assembler warning in line 10773
     syntaxcheck: Assembler warning in line 10831
     syntaxcheck: Assembler warning in line 10832
     syntaxcheck: Assembler warning in line 11392
     syntaxcheck: Assembler warning in line 69
     syntaxcheck: Assembler warning in line 173
     syntaxcheck: Assembler warning in line 239
     syntaxcheck: Assembler warning in line 285
     syntaxcheck: Assembler warning in line 331
     syntaxcheck: Assembler warning in line 377
     syntaxcheck: Assembler warning in line 423
     syntaxcheck: Assembler warning in line 469
     fan: Fan present but has no cur_state present.
     fadt: Both 32-bit FIRMWARE_CTRL and 64-bit X_FIRMWARE_CTRL pointers to the FACS are set but only one is allowed.
     fadt: FIRMWARE_CONTROL is 0xdef2df40 and differs from X_FIRMWARE_CONTROL 0xdef30d40
     fadt: FADT first reserved field is not zero: 0x01
     fadt: FADT PM1A_EVT_BLK has both a 32-bit and a 64-bit address set; only one should be used.
     fadt: FADT PM1A_CNT_BLK field has both the 32-bit and the 64-bit field set.
     fadt: FADT PM2_CNT_BLK field has both the 32-bit and the 64-bit field set.
     fadt: FADT PM_TMR_BLK field has both the 32-bit and the 64-bit field set.
    Low failures: 46
     dmicheck: String index 0x05 in table entry 'System Information (Type 1)' @ 0x000ebce5, field 'SKU Number', offset 0x19 has a default value 'N/A' and probably has not been updated by the BIOS vendor.
     dmicheck: String index 0x01 in table entry 'Processor Information (Type 4)' @ 0x000ebda0, field 'Socket Designation', offset 0x04 has a default value 'N/A' and probably has not been updated by the BIOS vendor.
     dmicheck: String index 0x04 in table entry 'Processor Information (Type 4)' @ 0x000ebda0, field 'Serial Number', offset 0x20 has a default value 'N/A' and probably has not been updated by the BIOS vendor.
     dmicheck: String index 0x05 in table entry 'Processor Information (Type 4)' @ 0x000ebda0, field 'Asset Tag', offset 0x21 has a default value 'N/A' and probably has not been updated by the BIOS vendor.
     dmicheck: String index 0x06 in table entry 'Processor Information (Type 4)' @ 0x000ebda0, field 'Part Number', offset 0x22 has a default value 'N/A' and probably has not been updated by the BIOS vendor.
     syntaxcheck: Assembler remark in line 5458
     syntaxcheck: Assembler remark in line 5676
     syntaxcheck: Assembler remark in line 6978
     syntaxcheck: Assembler remark in line 7237
     syntaxcheck: Assembler remark in line 7244
     syntaxcheck: Assembler remark in line 7287
     syntaxcheck: Assembler remark in line 7360
     syntaxcheck: Assembler remark in line 7603
     syntaxcheck: Assembler remark in line 7862
     syntaxcheck: Assembler remark in line 7869
     syntaxcheck: Assembler remark in line 7912
     syntaxcheck: Assembler remark in line 7985
     syntaxcheck: Assembler remark in line 9885
     syntaxcheck: Assembler remark in line 10399
     syntaxcheck: Assembler remark in line 10924
     syntaxcheck: Assembler remark in line 11268
     syntaxcheck: Assembler remark in line 11289
     syntaxcheck: Assembler remark in line 11295
     syntaxcheck: Assembler remark in line 11323
     syntaxcheck: Assembler remark in line 11329
     syntaxcheck: Assembler remark in line 11392
     syntaxcheck: Assembler remark in line 11425
     syntaxcheck: Assembler remark in line 11446
     syntaxcheck: Assembler remark in line 11452
     syntaxcheck: Assembler remark in line 11458
     syntaxcheck: Assembler remark in line 11481
     syntaxcheck: Assembler remark in line 11497
     syntaxcheck: Assembler remark in line 11517
     syntaxcheck: Assembler remark in line 11523
     syntaxcheck: Assembler remark in line 11529
     syntaxcheck: Assembler remark in line 11571
     syntaxcheck: Assembler remark in line 11667
     syntaxcheck: Assembler remark in line 94
     syntaxcheck: Assembler remark in line 97
     syntaxcheck: Assembler remark in line 123
     syntaxcheck: Assembler remark in line 212
     syntaxcheck: Assembler remark in line 222
     rsdp: RSDP: oem_id contains non-printable characters.
     lid: No lid interface available: cannot test.
     ac_adapter: Failed to detect any state in the ac_adapter state info.
    Other failures: NONE
    Test           |Pass |Fail |Abort|Warn |Skip |Info |
    ac_adapter     |     |    4|     |     |     |     |
    acpiinfo       |     |     |     |     |     |    3|
    acpitables     |   11|     |     |     |     |     |
    apicedge       |     |    6|     |     |     |     |
    apicinstance   |    1|     |     |     |     |     |
    asf            |     |     |     |     |    1|     |
    aspm           |    3|     |     |    4|     |     |
    aspt           |     |     |     |     |    1|     |
    autobrightness |    3|     |     |     |     |     |
    battery        |     |     |     |     |     |     |
    bert           |     |     |     |     |    1|     |
    bgrt           |     |     |     |     |    1|     |
    bios32         |     |     |     |     |     |     |
    bios_info      |     |     |     |     |     |    1|
    bmc_info       |     |     |     |     |    1|     |
    boot           |     |     |     |     |    1|     |
    brightness     |    3|    2|     |     |     |     |
    checksum       |   13|     |     |     |     |     |
    cpep           |     |     |     |     |    1|     |
    cpu_info       |     |     |     |     |    1|     |
    cpufreq        |    3|     |     |     |    4|     |
    crs            |     |     |     |     |    1|     |
    csm            |     |     |     |     |     |    1|
    csrt           |     |     |     |     |    1|     |
    cstates        |     |     |     |     |     |     |
    dbg2           |     |     |     |     |    1|     |
    dbgp           |     |     |     |     |    1|     |
    dmar           |     |     |     |     |    1|     |
    dmicheck       |   19|   10|     |     |    1|     |
    drtm           |     |     |     |     |    1|     |
    dt_base        |     |     |     |     |    3|     |
    dt_sysinfo     |     |     |     |     |    4|     |
    ebda           |    1|     |     |     |     |     |
    ecdt           |     |     |     |     |    1|     |
    einj           |     |     |     |     |    1|     |
    erst           |     |     |     |     |    1|     |
    facs           |    1|     |     |     |     |     |
    fadt           |   27|    8|     |    3|    2|    1|
    fan            |     |    1|     |     |     |     |
    fpdt           |     |     |     |     |    1|     |
    gtdt           |     |     |     |     |    1|     |
    hda_audio      |    2|     |     |     |     |     |
    hest           |     |     |     |     |    1|     |
    hotkey         |     |     |    1|     |     |     |
    hpet           |    1|     |     |     |     |     |
    iort           |     |     |     |     |    1|     |
    klog           |     |    1|     |     |     |     |
    lid            |     |     |    3|     |     |     |
    lpit           |     |     |     |     |    1|     |
    madt           |   50|     |     |     |     |     |
    maxfreq        |    1|     |     |     |     |     |
    maxreadreq     |    1|     |     |     |     |     |
    mcfg           |    2|     |     |     |     |     |
    mchi           |     |     |     |     |    1|     |
    mem_info       |     |     |     |     |    1|     |
    method         |  374|    5|     |     |  154|     |
    microcode      |     |     |     |     |    1|     |
    mpcheck        |    9|     |     |     |     |     |
    mpst           |     |     |     |     |    1|     |
    msct           |     |     |     |     |    1|     |
    msdm           |     |     |     |     |    1|     |
    msr            |   95|     |     |     |     |     |
    mtd_info       |     |     |     |     |    1|     |
    mtrr           |    1|    1|     |     |    1|     |
    nfit           |     |     |     |     |    1|     |
    nx             |    2|     |     |     |     |     |
    olog           |     |     |     |     |    1|     |
    oops           |    2|     |     |     |     |     |
    osilinux       |     |     |     |    1|     |     |
    pcc            |     |     |     |     |     |    1|
    pcct           |     |     |    1|     |     |     |
    pciirq         |    4|     |     |     |     |     |
    pmtt           |     |     |     |     |    1|     |
    pnp            |    2|     |     |     |     |     |
    power_button   |     |    1|     |     |     |     |
    power_mgmt     |     |     |     |     |    2|     |
    prd_info       |     |     |     |     |    1|     |
    reserv_mem     |     |     |     |     |    1|     |
    rsdp           |    7|    1|     |     |     |     |
    rsdt           |    1|     |     |     |     |     |
    sbst           |     |     |     |     |    1|     |
    securebootcert |     |     |     |     |    1|     |
    slic           |    1|     |     |     |     |     |
    slit           |     |     |     |     |    1|     |
    spcr           |     |     |     |     |    1|     |
    spmi           |     |     |     |     |    1|     |
    srat           |     |     |     |     |    1|     |
    stao           |     |     |     |     |    1|     |
    syntaxcheck    |    1|   56|     |     |     |     |
    tcpa           |     |     |     |     |    1|     |
    tpm2           |     |     |     |     |    1|     |
    uefi           |     |     |     |     |    1|     |
    uefibootpath   |     |     |    1|     |     |     |
    version        |     |     |     |     |     |    4|
    virt           |     |    1|     |     |     |     |
    waet           |     |     |     |     |    1|     |
    wakealarm      |    4|    2|     |     |     |     |
    wdat           |     |     |     |     |    1|     |
    wmi            |     |     |     |     |     |     |
    wpbt           |     |     |     |     |    1|     |
    xenv           |     |     |     |     |    1|     |
    xsdt           |    1|     |     |     |     |     |
    Total:         |  646|   99|    6|    8|  219|   11|
  5. namaiki
    namaiki "basically rocks" Super Moderator
    All of this is over my head, but first thing that comes to mind is maybe the GPU is toast?
