Sony Vaio Wipe and Erase
Discussion in 'VAIO / Sony' started by nokia42_2010, Aug 23, 2008.
  1. nokia42_2010
    nokia42_2010 Newbie
    Hi
    I hope you can help.
    I have damaged my screen and cannot see anything on it and want to get it repaired. However, before I do this I want to wipe and erase the data on the hard disk.
    If anyone has the same model, please can you provide a step to step guide on how to do this using a keyword, as I am doing it blindly.
    I look forward to your help :)
    Thanks,
  2. xrules
    xrules Notebook Consultant
    well another simple option is to buy a cheap hard disk .. and swap the hard disk.. (you will have your data when your notebook comes back .. as you can swipe your hard disks again.. ) or take your hard disk out, connect it to another pc, erase data and place it back..
  3. Trovador
    Trovador Notebook Enthusiast
    Connect your computer to an external monitor or projector using one of your video outs.
  4. DetlevCM
    DetlevCM Notebook Nobel Laureate
    If you have another computer you can try formatting your drive using an XP installation disc.
    You can "walk through" the details on another pc.
    No guarantee but I believe !!! that you files should not be damaged as long as you don't delete a partition or format anything on your instal.
  5. bogart
    bogart Notebook Evangelist
    You can also run DBAN on another computer, but don't run it completely, only to remember the keypress sequence that will allow you to wipe a drive, then repeat the keypress sequence on your notebook.
  6. nokia42_2010
    nokia42_2010 Newbie
    Thanks, I am running it now.
    How long is it likely to take on a 80gb hard disk?
  7. bogart
    It depends on the type of erase you chose. I'd keep it running until the HDD activity led stops blinking.
  8. nokia42_2010
    nokia42_2010 Newbie
    I typed "autonuke". Once I press enter does it start erasing without confirmation?
  9. bogart
    I'm not sure, it's been a while since I used that utility. Is the hard drive active after you type that? If not, probably there's another key you need to press. Try pressing F10. To get definitive answers, you should ask here.
