Sony Vaio SVP1321C5E: flickering screen on battery power after Windows 10 update
Discussion in 'VAIO / Sony' started by Troxelke, Nov 20, 2019.
  1. Troxelke
    Troxelke Notebook Enthusiast
  2. stepi
    stepi Newbie
    Where usable used old and b7000 glue
  3. Troxelke
    Ok thanks! Ordered the screen, looked at the DIY in YouTube, ordered the 61395 tape and hope for the best ;).
  4. stepi
    stepi Newbie
    Just be careful with bezel, it's really thin and fragile. Using heat gun or hairdryer for warming and softening tape/glue makes it much more easier.
  5. Robbin
    Robbin Newbie
    I've got a sony vaio pro 13 as well (SVP1322C5E), with identical issues which started for me as well after upgrading from win8 to win10. I've tried restoring the original image with win8 but the issue remains. I was convinced the issue was soft/firmware related but after reading this thread I'm in doubt. Can you please share your results after you have installed the new screen, I'm really curious.
    Robbin.
  6. TiToMoskito
    TiToMoskito Notebook Enthusiast
    Check the inverter under the bezel, this kind of series had some issues with it, so the backlight started to flicker.
  7. Troxelke
    I will do, I have the screen now at home, now find some time to fix it!
    Ahh thnx! So how can this inverter be fixed?
  8. TiToMoskito
    The only way to fix it, is by replacing it.
  9. Troxelke
    I am sorry it took a while before I found some time to replace the screen .... but YES it solved the flickering of the screen! I am very happy!!
    It took me about 2 hours, as I had never done this before. The tape is pretty sticky, but with proper opening tools it is pretty easy (with some patience haha).
    Just be very very careful on the flex that goes to the digitizer/touchscreen part, that is on the bottom center (so in middle of bottom bezel).
    I got a lot of help by a DIY movie: just search on Youtube for "Sony Vaio Pro screen replacement" for a good video to support you.
    Roy.
    I now changed the screen, and now it is solved! Is the inverter part of the screen, so that is why it is solved?
    Thanks again for your help!
    stepi likes this.
  10. stepi
    stepi Newbie
    I am not sure if there actually is inverter at all on this display, if i remember correctly there is no invertes on led displays. But anyway, I am just happy with my non flickering display :D
