Sony Vaio SA/SB/SC/SE Advanced Menu BIOS Hack
Discussion in 'VAIO / Sony' started by pyr0, Jan 28, 2012.
  1. acik84
    acik84 Newbie
    Yes, that's what happened to me :) Still waiting for my notebook return from waranty. :(
  2. lamoon2012
    lamoon2012 Newbie
    Does This Work On Vaio . Bios R019020 ? :)
  3. pyr0
    pyr0 100% laptop dynamite
    Update: Changed BIOS backup procedure, so no malware notices will be raised by stupid AntiVirus software.
    Please provide the full model number.
  4. wolverex
    wolverex Notebook Enthusiast
    Hi you mentioned something about Always Enable PEG on the Z1 thread and said "smells like we have freed another nice laptop from bad drivers"
    could you elaborate? sorry should we change this setting to disabled?
  5. mtroyan
    mtroyan Newbie
    Again, any progres unlocking sata3?
  6. AKZam
    AKZam Newbie
    Yes I had already enabled AHCI in regedit, and I am not running RAID0 (only one drive). Hmm, ill keep playing and see if I can get past BSOD.
    Any other things you think could be causing it?
    EDIT: After some further testing (including re-installing a fresh copy of windows), it seems to BSOD if changed to either AHCI or IDE, so anything other than RAID... Not really sure what else to try - btw I am using the latest version of the modded bios, is it worth trying the older version?
  7. NICEof
    NICEof Newbie
    What progress in unlocking SATA3?
  8. yuanhaoliang
    yuanhaoliang Newbie
  9. pyr0
    The development is on hold since there is yet to find a VAIO S owner that is willing to collaborate and has a SPI flasher and soldering skills. If anybody donates a (broken/bricked) VAIO S, I will look into that deeper.
    I won't release anything that is untested and can possibly brick anybody else's machine.
  10. lenorman
    lenorman Notebook Enthusiast
    what about the fan speeds/noise - seems a major issue - any progress on that? or a way to control it so its not a jet engine/hoover in the background
