Sony Vaio Picturebook PCG-C1 XS in... 2019!
Discussion in 'VAIO / Sony' started by sev7en, Jul 12, 2019.
Tags:
  1. sev7en
    sev7en Notebook Consultant
    Good morning,
    I purchased on eBay this wonderful jewel with the configuration following:
    • Processor: 400 Mhz Intel Pentium II
    • Memory: 64 MB
    • Graphics: Neomagic AV256 2.5MB
    • OS: Windows 2000 SP4
    • Storage: 80 GB HDD
    and I tought to upgrade the hard disk by purchasing a more "modern" hybrid SSD as the PATA KingSpec 256GB 2.5-inch PATA/IDE SSD Solid State Disk (MLC Flash) SM2236 Controller.
    Now the problem is if I go in the BIOS this unit is recognized by if I select the value all are ones reported than the real size of the SSD.
    If I set AUTO nothing is done and when I try to install the operating system I get error messages (as hdd not found and similar).
    Which one is the maximum supported HDD size? How can I use it?
    thanks!!!
  2. User32
    User32 Notebook Deity
    KingSpec SSDs are garbage, just get a mSATA-IDE converter and a mSATA SSD, preferably one that isn't bigger than 120GB because LBA.
  3. sev7en
    Good morning,
    thanks... and for my current sutup there is a solution?
    Cheers,
  4. User32
    Using drive overlay software might help.
