Sony Vaio Grv215sp Laptop Problem
Discussion in 'VAIO / Sony' started by nsathisha, Sep 17, 2008.
  1. nsathisha
    nsathisha Newbie
    Iam getting below message and not able to login to windows.
    a problem has been detected and windows has been shut down to prevent damange to your computer.
    If this is the first time you've seen this stop error screen, restart your computer. If this screen
    appears again, follow these steps.
    check to be sure you have adequate diskspace. if a driver is identified in the stop message.
    disable the driverof checkwith the manufacturer for driver updates. Try changing video adaptors
    check with your hardware vendor for any bios updates. Disable bias memory option such
    as catching or shadowing. if u need to use safe mode to remove or disable components, restart
    press f8 to select advanced start up option and than select safe mode.
    technical information:-
    *** stop: 0x0000008E (0xc0000005, 0x904D92C2, 0xF8CA55A4, 0x0000000)
    beginning dump of physical memory
    physical memory dump complete.
    Contact your administrator or technical support group for further assistance.
    If i open in safe mode i will get the below message
    multi(0)disk(0)rdisk(0)partition(1)\windows\system32\drivers\intelide.sys
    This laptop was formatted without using the sony recovery cd.
    Please let me know is this because of that?
    How to recover my laptop to normal condition?
    thanks in advance.
    Satish
  2. DetlevCM
    DetlevCM Notebook Nobel Laureate
    Blue Screens of Death (BSoD) can have numerous causes.
    (on my SZ Windows Update messed up the EOS driver, I turned the camera on... BSoD, Kaspersky caused problems too, now their gone as if by magic)
    You could try to reinstal the driver, you know which one it is: "intelide.sys"
    (See Google, something to do with Intel)
    Else, unless you've generated your own recovery disk or left the recovery partition the only things I can think of is:
    do a clean instal
    Buy a recovery disc from Sony
  3. gecko
    gecko Notebook Evangelist
    Old thread but if the OP is still hanging around, and still needs a fix. I think I got know the fix, but it's going to be a long confusing process.
    Reply if you want to know the steps.
  4. Babydarklord
    Babydarklord Notebook Evangelist
    One of fastest way to fix BSOD if this will a be Software issue is System restore using f10. If try that already and reformat the system and still the same issue that for service already.
