Sony Vaio EB Left and Right Click Buttons Don't Work!
Discussion in 'VAIO / Sony' started by Drew1, Oct 13, 2010.
  1. Drew1
    Drew1 Notebook Evangelist
    Received my sony vaio 15.5 laptop today. It looks great. However, does anyone know why the left and right click buttons below the touch pad does not work? The touchpad where i move my cursor is good and i can click using it. However, the left and right click does not work. Can someone tell me why?
    Thank you!
  2. Drew1
    Hey everyone. I received my sony laptop VPCEB390X. I am frustrated with this laptop because after i opened it up and loaded it, the left and right click buttons of the touchpad did not work. The touchpad where you move the arrow worked fine. I then spoke to tech support online and on the phone and we did the screen sharing etc. After he did some changes, my touchpad is now erratic like no tomorrow. I cannot move the touchpad correctly whatsoever. Also, it seems that the left/right buttons of touchpad works now but it keeps on messing up. Does anyone have this problem? I click on it but it keeps looking like i am right clicking everything.
    Support tells me they will call me in 1 day to get something set up and have a technician come in 6-7 business days. However, i read that sony support is horrible. I am frustrated now and rather just return this laptop instead. I mean if i plug in a mouse, everything works fine but the touchpad is just erratic and seems to keep clicking itself.
    Anyone have suggestion on what to do?
  3. mih11
    mih11 Notebook Enthusiast
    Just sounds like you have a faulty unit. Tell them you expect a replacement shipped out immediately and they can take the faulty one when they deliver the replacement.
    Support is only ever as bad as you let it be. Get angry and ask to speak to higher management.
  4. Drew1
    Okay right now at this moment the mousepad is okay but not that great. The left and right click works now. However.... the left click RIGHT CLICKS instead. I can confirm this because when i right click on background, i see the same thing when i left click it. Do you know if this is some setting problem instead? The left and right click works but left click right clicks...
  5. as41
    as41 Notebook Guru
    I would ask sony to replace the unit asap. It definately seems faulty.
  6. Drew1
    Thanks as41. Anyone else? I am really hoping i could fix this problem because this laptop LOOKS VERY GOOD. If they have a technician come over, would he be able to fix this problem? I know i have 30 days to return it.
  7. Fireblade-rider
    Fireblade-rider Notebook Enthusiast
    Hi there, I think that I might be able to help you solve this problem, in the notification area there should be an icon for the touchpad, right click this and then click Mouse Properties, then on the window that appears, it should display the Buttons options, if not then click on the buttons tab, at the bottom of the buttons options you will see a button that says Default, click this and then try the touch pad buttons again and see if they are ok now. I hope that this helps.
  8. Drew1
    Where is the notification area? I don't see any of this stuff you are mentioning...
  9. Drew1
    Okay i see it. I see button configuration with switch and secondary buttons but i read online that is for left handed ppl.
    Then i see click lock ...
    Which are you talking about?
  10. Fireblade-rider
    Also, under the buttons options, check to see if the list reads as follows, Left Button (Click), Right (Shortcut Menu).
