Sony Vaio disassembly guides and instructions
Discussion in 'VAIO / Sony' started by cj2600, Nov 5, 2008.
  1. levicki
    levicki Notebook Guru
    Any service manuals for VGN-FW series?
  2. Turbo9
    Turbo9 Notebook Enthusiast
    Great, maybe the moderator should post a new thread fro the AR series, and add this pdf to it? Just an observation
  3. chibits
    chibits Newbie
    anyone can find a guide for the CR series? particularly how to upgrade the CPU. thanks
  4. SSDVaio
    SSDVaio Notebook Guru
  5. Peto
    Peto Notebook Enthusiast
    People
    Aand What about AW Series ???
  6. ngvuanh
    ngvuanh Notebook Deity
    It is MicroDIMM DDR333 172-pin. You can buy some on ebay.
    http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=microdimm&_sacat=See-All-Categories
    http://www.ewiz.com/detail.php?p=D27MA12G&c=pw#
  7. google123
    google123 Notebook Enthusiast
    I would really appectiate a link for the SR series as well. Thanks!!!! :)
  8. claysmc
    claysmc Newbie
    Thanks so much for doing this. I spent hours trying to find guides to disassembly my vaio. It would have been impossible without your guide.
    Again, Thanks!!!
  9. NiKoMatsu
    NiKoMatsu Newbie
    I have successfully disassembly a VAIO VGN-FW290 flawlessly.
    I wanted it open because my power cable connector was loose, probably because of an unwanted hit (that cracked the magnesium alloy support). Because I was on a hurry I couldn't make a picture guide. And because I used it on a daily basis I can't afford dissasembling it to make a step by step guide.
    If anyone want some advice or is stucked somewhere I wouldn't mind helping.
    But if you have patience you will probably figure out for yourself, there are no tricks or hidden screws. It's just reverse engineering for the assembly process.
  10. Duplicated
    Duplicated Notebook Geek
    Can I ask some quick question about how to remove heatsink from my Vaio SZ series please?
    As you can see in the picture, I can't remove that screw. I tried to apply more force on it, but it just wouldn't budge. I think the other screw underneath that one requires the same screwdriver's size right?? I can remove that one relatively easy, but not the other one
    Any help right now would be appreciate :)
