Sony TZ and SSD Express card
Discussion in 'Sony' started by Mishmish, Aug 28, 2007.
  1. Mishmish
    Mishmish Notebook Enthusiast
    The performance of my TZ160C is not so great. It came with 1GB RAM, and I am upgrading it to 2GB. It has 100GB hard drive. It is a 1.8" one. My query is about adding a 16GB SSD Express card, where I will install Vista. Will that boost my TZ performance? Is there a better solution?
  2. Phil
    Phil Retired
    Good question. I have no experience with it, but my guess would be: no. because of the limited bandwith within the TZ.
    Yes a clean install of Windows XP will seriously boost your performance. You don't even need 2GB in XP.
  3. Mishmish
    Thanks, PhilFlow,
    I am sorry for my ignorance. Could you please elaborate on the "TZ's limited bandwith". What do you mean by that? How come it has limited bandwith?
  4. zerodays
    zerodays Notebook Consultant
    mishimishi, i think u need some tweaks to
    allow installations and bootings.
    You will definitely benefit using express SSD as compared to your 1.8inch 4200rpm hdd. I can confirm this as I read several websites and forums. But sorry i do not have any further info or links.
  5. Phil
    Phil Retired
    I don't know what thread but I think it's the TZ owners thread.
    People found out that devices conncted to the TZ like a USB harddrive do not get full speed. Futher on, any device connected eats bandwith from the others. So if you are using a bluetooth mouse it eats bandwith from a usb drive.
    Details are in another thread, and I am not 100% sure if this is applicable to the expresscard.
    It's not strange because Sony TZ is so small, it has a very tiny motherboard that comes with some limitations.
    You mean you read this specifically for Sony TZ?
  6. zerodays
    philFlow, not here, it was other forum.
  7. Phil
    Phil Retired
    I mean did you read this info specifically for TZ?
    Sure I can understand a Flash expresscard can boost performance, but the TZ is a different ballgame.
  8. zerodays
    Phil, yes I am well aware of the fact that ExpressCards are routed via USB hub, etc. But I read that all expresscard made for laptop are USB-routed...
    I think.... the performance *will* boost if a user came from using 1.8 4200rpm HDD.... but if a user uses anything 2.5inch, which is likely to be 5400 or 7200, then I don't think expresscard SSD will benefit....
    Sorry, I really have no idea about the links or source. This is because for a last couple of weeks, I was really mad surfing everywhere for SSD info, SSD vs HDD, etc, etc. hehe;;
    So far, MySSD brand have expresscard SSD (up to 16GB) SLC model that can do 10MB/s write (as compared to Lexar or others that only do 3MB/s write)
    Ok, Ive found some info, they are in Korean (so probably useless... but apprently ppl do 'mod' and strive to install expresscard SSD to improve speed)
    http://blog.empas.com/miracleboy1120/22404981
    http://tong.nate.com/hanul13/39444437
  9. Phil
    Phil Retired
    yeah that information is not specific to TZ.
    I am looking forward to anyone testing a SSD expresscard on TZ!
  10. vaiouser
    vaiouser Newbie
  11. jc4ho
    jc4ho Notebook Consultant
    Considering that it's built for professional camcorders, it's probably going to cost 2 arms and 2 legs.
  12. Moonraker
    Moonraker Newbie
    Here's the thread about USB band width issues with the TZ. http://forum.notebookreview.com/showthread.php?t=126899&page=56
    Hope that helps but I'm surprised that the Express Card uses USB band width. Blue Tooth and internal DVD almost certainly do. Internal 2.5" HDD uses either PATA or SATA (depending on who you tak to??) so has no effect on the USB band width. The FireWire port also seems to be independent.
    I'm still waiting for my machine so I can't confirm this personally.
