Something is Wrong with my XPS 15 When I try to undervolt
Discussion in 'Dell XPS and Studio XPS' started by EORUCIGN, Jul 10, 2018.
  1. EORUCIGN
    EORUCIGN Notebook Consultant
    I am sorry that I am posting a lot of threads, but I am really concerned about my new baby here. Ok, I am really skeptical about my undervolting method. I recently got my Dell XPS 15 9570, and was shocked by the power limited throttling, that when I play games, the CPU goes down to 0.8 GHz. So I thought I gotta do some undervolting by xtu and throttlestop. Now here comes my skepticism.
    I was able to make Core and cache voltage offset to -200mv and Intel graphics card voltage offset to -150mv, which sounds crazy for me unless I am really lucky. I ran prime 95, and it does not show any blue screen, and the temperature is around 75 ~ 80c, so it looks good so far. However, whenever I enter XTU, for some reason, it is recommending me to reset my voltage to normal which is a bit odd in my opinion.
    Also, when I watch a youtube video, sometimes the sound crashes and I am not so sure this is due to undervolting or not. What do you guys think? Is getting -200mv reasonable or just something wrong with my unit?
  2. EORUCIGN
    ok finally my -200v showed some blue screen, now I might be able to find my sweet spot.
  3. pressing
    pressing Notebook Deity
    You can not undervolt to -200mv and expect no crashes.
    Review the posts here and you will see some people claiming -150mv. That varies by system. You should start with a less aggressive undervolt and stress test for a few hours. If that is good then maybe another -10mv.
    I would hope your CPU can be stable in the -120 to -140 range but not much more under stress.
    Woodking likes this.
  4. EORUCIGN
    That's what I was thinking as well. Since I got my first bluescreen on -200mv, now I am slowly dropping my voltage to find some sweet spot.
  5. antik
    antik Notebook Geek
    Yeah I don't think I've seen anyone run -200mv stable. Start at -150mv and go from there. I'm able to run mine at -190mv stable, but I consider myself one of the lucky ones
  6. Eason
    Eason Notebook Virtuoso
    Don't use XTU, it's broken. Use throttlestop.
    Papusan and unclewebb like this.
  7. Woodking
    Woodking Notebook Evangelist
    Fully agree. Throttlestop is a great little utility and does a good job as long and you test your settings 1. actually are working, and 2. leave the system stable/reliable.
  8. Danishblunt
    Danishblunt Guest
    Did you repaste that system? Throttling to 800mhz is extremely severe.
  9. EORUCIGN
    I was able to have stable -190mv but after I restarted my laptop, for some reason, throttlestop changed my setting to default. So it seems like 190mv is no good for me
  10. EORUCIGN
    Not yet. I will get my thermal pad today!
