something is wrong with my sound
Discussion in 'Dell XPS and Studio XPS' started by red123, Jul 19, 2008.
  1. red123
    red123 Notebook Consultant
    For some reason, when I use my earphones, I will hear this annoying clicking sound whenever I double click on everything. I tried using a different earphones and the same thing happens. However, when I play some musics, the clicking sound will not be audible. Even when I play winamp at the lowest possible volume (basically no sound), there is no clicking sound. Anyone have any idea what is up with my sound? The sound is like a popping sound.
  2. walidism
    walidism Notebook Consultant
    hey here are a few steps you can do to try an isolate it.
    1. restart your computer and see if the clickin sound is happening at any phase during the boot up, or early after the boot. if it doesnt click during these two phases, but later after cpu use, then it could be a problem with the cpu.
    2. another thing you can try is reinstalling your soundcard driver. whenever you install programs and stuff there is always a chance ur drivers interfere. to uninstall the sound card driver, go to computer management in control panel (xp), it should be in administrative toools folder,
    in comp. management, find device manager... and find sound, vide and game controllers. find the soundcard driver, right click and uninstall, then reinstall (it'l prob happen after a reboot).
    note: when you say this clicking sound... do you mean like a noise clicking sound or a distortion type clickin sound? cause if it's the noise thing then u can just disable windows sound schemes.
    finally, does the click sound occur only with headphones, or even on the speakers?
  3. red123
    The clicking/popping sound is similar to the one this person is experiencing (person in 2nd post). http://forum.notebookreview.com/showthread.php?t=211527
    I tried restarting and I am receiving constant static during the early boot up. I am not sure how that would help solve the problem. And I have tried uninstalling and reinstalling my sound card driver prior posting this thread. The clicking sound occurs only on headphones, but I have not tested it out on speakers yet. Occasionally I would hear around 5 clicks after clicking on something.
    Strange thing is when I open winamp and play some music (even if I mute the music), it stops making that same sound (the sound is quite loud on my earphones even at volume of 3). I even tried opening a game that takes up the whole screen and it will have the same effect as winamp.
    EDITED: Disabling the Window Scheme helps with the problem a little bit, but I am still getting the same sound whenever I open something. It's weird how this just started happening after not using my laptop for weeks.
  4. RCcola159
    RCcola159 Notebook Guru
  5. red123
    It's not that sound. It's not about the double clicking, its about me opening a file or a folder. The sound that I am talking about can be downloaded in this thread http://forum.notebookreview.com/showthread.php?t=211527. I actually like the window scheme sound =), but this I do not like =(. Not sure if it is static.... But it is weird how it only happens when I am not playing any sound.
  6. walidism
    try and find out if it occurs only when you use the headphone jack, or even with the internal speakers. this way you can see if it's the jack, or the driver itself. i think it might be something wrong with the jack. can you set the other jack on the laptop to accept headphone input and test it on that, what software is your soundcard installed with?
  7. red123
    It happens in both jack, but for some reason any other sound that is running on the laptop will override that clicking sound. I am not even sure why it is that, but I will try to connect my speakers to my laptop tomorrow and see.
  8. walidism
    alright so both jacks are whacked up, which means it could be a static offset inside the metal hinges of the jacks. ill have to do some digging to see if there is a viable cost-free solution :D but don't worry we'll get to the bottom of this.
    have u tried it with just the laptop's built in speakers? if its what i think it is then the laptop speakers shouldn't make that sound. let's hope im right.
    good luck!
  9. red123
    Yea laptop speakers are fine fortunately =D. So if I send my laptop in, will Dell replace it with a totally different laptop or try to fix it? I really like my LG screen =/
  10. walidism
    no i don't think they will replace the laptop they'd have no need, and they certainly won't change anything about it other than the problem.. they might replace the hardware for the soundcard. good thing your laptop speakers work cause we've narrowed it to the metal inlays of the headphone jack. if you send it in, dell has no right to change anything other than what you asked for without consulting you. you can either send in for a replacement or tell them to work on it and fix the staticness, at least now you know where to guide them.
    you got an lg screen for your laptop? or monitor? cool i have an lg laptop and the screen is brilliant.
    good luck, im here if you need me
