Some body Help me, please
Discussion in 'HP' started by irhandi, Dec 7, 2017.
  1. irhandi
    irhandi Newbie
    Dear All,
    have a notebook with a general specification of the brand Hp Pavilion Notebook with windows 10 operating system, the notebook I have been using for a year, but now the notebook has a problem that if I press the '' left Shift '' on the keyboard it will show the letter '' X '' and if the "Shift right" button is pressed it will display the letter "W".
    In the previous few months the notebook has experienced a problem that if I press the key with the '' character on the keyboard it will appear the letter '' @ '', but it can I overcome by changing the language settings.
    I hope the experts could give me the solve problem this matter.
    thanks and regards,
    irhandi
  2. Vasudev
    Vasudev Notebook Prophet
    might want to check keyboard ribbon and clean it a cloth and check again.
    Try a power reset, see if it helps in sorting your weird issue.
    You can try key remapping software from this link https://lifehacker.com/5883003/the-best-key-remapper-for-windows
  3. irhandi
    irhandi Newbie
    Thanks so much for your advice and the keyboard I checked and I make sure it is clean, but it does happen.
    I will try to use the tools as suggested. if it still problem i would like give inform to you
    thanks and appreciate....
    Vasudev likes this.
  4. irhandi
    irhandi Newbie
    Vasudev likes this.
  5. Vasudev
  6. irhandi
    irhandi Newbie
    Maybe its time to replace the keyboard.[/QUOTE]
    hehehehehehe
    Vasudev likes this.
