Software to load test batteries in Toughbook
Discussion in 'Panasonic' started by Shawn, Oct 4, 2018.
  1. Shawn
    Got a couple new old stock batteries that act odd.
    What is available to test them?
    Preferably it will test both batteries in the laptop as the unit has both installed.
  2. User32
    User32 Notebook Deity
    HWInfo? BatteryBar?
    Shawn likes this.
  3. BaRRmaley
    BaRRmaley Notebook Deity
    Shawn likes this.
  4. Shawn
    I will investigate those ideas. Will they test the batteries or just report power levels?
    What I am hoping for is a benchmark type of test that also records the battery statistics as the system is run at maximum for a period.
    The batteries don't act strange until a high constant load is put on them. Such as loading Windows 7 or other large software packages.
    Maybe I need 2 bits of software. One to benchmark the system and one to record battery levels, temperatures, etc as the system is benchmarked.
  5. User32
    BatteryEater?
    Shawn likes this.
  6. Shawn
    Results from Battery Eater. Over 6hrs run time on a U1 mk1.
    SHEEPMAN! and toughasnails like this.
  7. User32
    "Enchanted SpeedStep"
    So it magically gives the Atom SpeedShift Turbo Boost?
  8. Shawn
    It has a magical fairy that overclocks the cpu.
  9. BaRRmaley
    SpeedStep is a dance.
    User32 and Shawn like this.
