Software for correct AVCHD conversion to MP4?
Discussion in 'Windows OS and Software' started by Type 100, Apr 23, 2012.
  1. Type 100
    Type 100 Notebook Enthusiast
    I've got a Panasonic Lumix LX5, and I use it to shoot video sometimes. It's been set to output footage into AVCHD.
    Wanting to get the footage into a more universal format I've been trying to convert the files into MP4s using HandBrake and AnyVideoConverter. However, both utilities seem to render the video at a higher speed compared to the audio, so there are synchronization issues. Also, the files end prematurely - when the video ends, the lagging audio ends as well.
    Do you know any other utilities I should try for AVCHD conversion into MP4? Thanks in advance.
  2. ViciousXUSMC
    ViciousXUSMC Master Viking NBR Reviewer
    Handbrake Should Work, it maybe a setting issue.
    I personally use MeGUI I prefer it to Handbrake its a lot more customizable and more advanced.
    If you can upload a clip for me I will test it to make sure all is well.
  3. Type 100
    Yeah I was thinking the same thing; maybe the audio-video sync settings were just mucked up. I'm pretty new to HandBrake and I haven't had to tweak it extensively until I got to AVCHD conversion, where I got stuck.
    Thanks Vicious; I'll see if I can upload something by tonight so you could try your hand at it. Where should I upload? Do I do it directly here on the forum or should I host it somewhere? I have little experience in uploading video files.
  4. ViciousXUSMC
    Dropbox or Skydrive are both good things to have as personal storage space that allow you to share files. (I can give you a referral link to get extra free space for dropbox)
    You can always use a 3rd party host like rapidshare or similar.
  5. Type 100
    Been a while since I last replied, very sorry, but I did some tinkering with Handbrake 0.9.6 and I finally got the settings right for proper conversion to MP4 without my A/V sync issues.
    Apparently you just have to make sure the output framerate matches the source material's.
    I hope this helps!
    And thanks Vicious - I never took you up on your offer to hunt down the proper video conversion settings but the offer is really appreciated :)
