Smaller power adapters?
Discussion in 'Sager and Clevo' started by StrangeINTP, Dec 24, 2019.
  1. StrangeINTP
    StrangeINTP Newbie
    I have an NP8454. The power adapter is ... well, a brick. It's quite large, and somewhat limits portability, for taking it on travel and such.
    Are there smaller power adapters compatible with it? I don't mind sacrificing a bit of wattage even to the extent of slowly discharging the battery, as my sessions when I take it on travel are not really that lengthy or power-hungry, and I'd rather shed the weight/bulk. (Sager website identifies the 8454's power adapter as 230 W.) I suppose the main thing is to have a compatible charging connector, but I don't know how to check that short of buying another adapter and physically trying it.
  2. Meaker@Sager
    All the 230w bricks are a certain size, it's dangerous to use a lower rated brick with the device.
  3. win32asmguy
    My N970TF actually came with a slightly smaller and lighter Chicony 230W brick than my friends Powerspec 1720 (PB70EF-G). The part number is A17-230P1A. Both bricks worked fine with either laptop.
  4. Meaker@Sager
    Yes, so long as its rated for the output that's ok but the differences are going to be small.
