Skyrim Volume too low? maybe a fix here (worked for me)
Discussion in 'Alienware M11x' started by el_pitaya, Nov 13, 2011.
  1. el_pitaya
    el_pitaya Notebook Consultant
    Well I'll make this a thread so I think more people will look at it
    When I installed skyrim on my r1 everything was fine, I just noticed that the game volume was too low
    I left the game with the main screen to hear the song and I culdnt hear it without headphones or from 3 meters from the m11x so I found this fix on the internet and some of mine
    on the control panel > hardware and sound > sound menu
    select your speakers (realtek high definition audio for me) then > properties > then go to enhancements tab > and check the loudness equalization, then re-launch skyrim, and check for differences on audio, this helped me but
    then I went to the SRS tab on the sound menu checked to enable SRS technology (this is from realtek HD audio controller) and selected the game option
    then the game really sounded really good and noticed I can hear everythig just fine and not with max volume
    I hope this helps also I have on the advanced tab the sound set to Studio quality 24 bit, 44000 Hz
    greetings from skyrim brothers!
  2. Der0p
    Der0p Newbie
    I just registered to say Skyrim really has a low volume (maybe only happens in some computers).
    I tried the loudness equalization fix as you said and it really worked for me, and now the volume is higher.
    Saludos carnal :p :)
  3. alienowl
    alienowl Notebook Consultant
    I tried both these suggestions and the sound seems to be better now. I will test more :)
    Thanks!
  4. Jock in a Frock
    Jock in a Frock Newbie
    Same for me - I just registered to say this worked for me. Many thanks to the OP.
  5. simply anonymous
    simply anonymous Notebook Geek
    yep had this problem with my Asus G73J notebook, this fixed it.
    CHeers
  6. Mackzzor
    Mackzzor Newbie
    Registered just to be able to say that this worked for me! Thanks alot man :) The audio was very low before and I had to turn it up on my headphones everytime I wanted to play! Thaanks :D
  7. thomyorke107
    thomyorke107 Notebook Enthusiast
    Hi all, Im having the same low sound problem with low sound on my M17x-R3!
    Im not seeing the SRS tab on my audio player in Sound (IDT High Definition Audio on mine).
    If anyone could be more specific on where this was I would be forever appreciative.
  8. WILLY S
    WILLY S I was saying boo-urns
    Thanks for this, worked a charm ;)
  9. eats7
    eats7 Notebook Evangelist
    thanks works well!
  10. scholar80
    scholar80 Notebook Guru
    Thanks, this worked for me too.
