Simple and very effective cooling "mod" for p775dm2/p775dm3
Discussion in 'Sager and Clevo' started by tanzmeister, Apr 13, 2017.
  1. Papusan
    Yeah, You need one for Coffee. Another one, but for Coffee.
  2. johnbb
    johnbb Notebook Consultant
    Wow! Amazing copper IHS. Do you see any improvement over the stock one?
  3. Meaker@Sager
    The stock IHS is nickel plated copper by the way.
    Vasudev likes this.
  4. Papusan
    Same with the Bitspower lid:)
    Vasudev likes this.
  5. oSChakal
    oSChakal Notebook Consultant
    Posting here because I'd like to know if it's possible to simply unscrew the heatsink while leaving it in place and sliding the paperclip or do I have to remove it completly?
    Thanks!
  6. Kittys
    Kittys Notebook Evangelist
    It is much easier to just remove it and do the mod.
  7. Mikki79
    Mikki79 Notebook Guru
    Well I tried this mod and for me it didn't do anything unfortunately, GPU 75c load Before, 75c load after. I guess it was as good as it gets already.
    But I couldn't do it as well either, the heatpipes are welded/soldered whatever so far to one side that it's not really very possible to lay the paper clips from one side to the other, did it more like a C shapre in each side. Maybe that didn't give as much support. Under one of the spring arms it wasn't even possible to put any paperclip
    Tried to put some small wooden sticks under the CPU arms that did nothing either. Well actually it's hotter than after the first time I delided the CPU, but I don't think that's because of this. The CPU has just gotten a bit hotter over the past year for some reason. Well a couple of more years and this laptop will be completely outdated anyway. 6700K :/ kinda outdated already.
  8. martin darlington
    martin darlington Notebook Enthusiast
    a great mod,so simple but very effective, i did not know there was a lack of pressure to the cpu and gpu plates i have a 775 so may well try this, did you see a temp improvement ?
    very clever though,thanks.
  9. bennyg
    bennyg Notebook Virtuoso
    Check whether there's still sufficient liquid metal under the lid, it may have moved or soaked into the IHS
  10. DRevan
    DRevan Notebook Virtuoso
    Has anyone tried this with the P775TM and gtx 1080? Did it help to lower the gpu temp from 85-88C?
