Simple and very effective cooling "mod" for p775dm2/p775dm3
Discussion in 'Sager and Clevo' started by tanzmeister, Apr 13, 2017.
  1. johnbb
    johnbb Notebook Consultant
    Well the temperature is low enough for me. I'll leave it that way :)
    It would be a bummer to kill my 1070...
  2. DuongTHVN
    DuongTHVN Notebook Guru
    wow, will try that for my P775DM3-G too.
  3. DARCODER
    DARCODER Notebook Deity
    i received a new heatsink and when i apply grizzly metal, gpu was reaching 97 in boot then shutting down ( i guess no contact) , i apply your trick and ic7 and pressure was back and even better temp, gaming max 52*c. Cant wait to test with liquid metal, Awesome research+++
    steberg likes this.
  4. Mobius 1
    Anyone tried with vapor heatsink?
  5. tanzmeister
    tanzmeister Notebook Evangelist
    for vacuum chamber only pad replacement will work or a much harder mod, requiring drilling and thin spring tounge-like sheet( or old p170xx HS toungues) . I usually use thermal paste on vRAM instead of pads and push the rest of the pads by thumb a bit down..
  6. DARCODER
    what thermal paste you are using on vram? because it hasnt to be thick since pads are a liltle thicker than a paste?
  7. Meaker@Sager
    Drilling and vapor chamber sounds like a bad combination...
  8. Z3us_PL
    Z3us_PL Notebook Consultant
    Any ideas how to incrase heatsink presure to CPU on P775TM?
  9. johnbb
    Should be the same paperclip trick as for the GPU HS. Although results should be much better if you CPU is delid
  10. DM g
    DM g Notebook Guru
    No luck with p750dmg also I broke some clips in my keyboard when I try to find my bad speakers. I tried on gpu, my heatsink is different, I cant use stick for cpu. Can I use p775dm3 heatsink in mine?
