Simple and very effective cooling "mod" for p775dm2/p775dm3
Discussion in 'Sager and Clevo' started by tanzmeister, Apr 13, 2017.
  1. tanzmeister
    tanzmeister Notebook Evangelist
    Hi everybody! i ve finally decided to share my finding on making the cooling better for the Clevo p775dm2/3 better while still keeping it simple and easy.
    a while ago i have made a post about p870dm/dm1 thermal pads layout that helps to make a better heatsink/die contact. but that was a bit complex task and does not always give the best results, especially when it comes to unified HS like p7xx does!
    recently i have found a much better, simple and effective way to do it, without even changing the thermal pads.
    so far this has been tested on all p7xx models and p870dm/dm2/dm3/km models except for the GRID sli heatsink(this need some more thoughts to be made)
    i attach the pictures, i am pretty sure it simple to understand what have been done, so i will not go into much details, but if you will have questions - feel free to ask!
    [ IMG_2253 (2).JPG IMG_2255 (2).JPG IMG_2257 (2).JPG IMG_2256 (2).JPG IMG_2251 (2).JPG
  2. tanzmeister
    IMG_2252 (2).JPG more to come
  3. clevo-extreme
    clevo-extreme Company Representative
    We use this method from always
    Gesendet von meinem SM-G935F mit Tapatalk
    Dr. AMK, tanzmeister and Xavier2612 like this.
  4. tanzmeister
    i wish i've learned this earlier! ;)
    Xavier2612 and clevo-extreme like this.
  5. Xavier2612
    Xavier2612 Notebook Consultant
    not all of us:)
    tanzmeister likes this.
  6. Xavier2612
    more details for other may help like me :)
    add as much as you can please:)
  7. tanzmeister
    Please ask if you are missing something - i will gladly expand on that!
  8. Mr. Fox
    I get what's going on in post #1. You are using toothpick segments on the CPU spring arms and plastic coated paperclips under the GPU spring arms as a fulcrum to increase contact pressure. What a slick way to increase pressure on the CPU and GPU die. Great idea. Thanks for sharing it.
    I don't understand what I am looking at in the photograph in post #2. What are the three metal strips? What purpose are they serving and where do you get the materials for that? Also, why only on three sides instead of all four? Are they glued down, and do you have any insulation on the bottom of the metal strips to keep them from shorting on components underneath them?
    Prostar Computer likes this.
  9. tanzmeister
    you mean around the DIE? thats just standart clevo stripes that are there by default.
    the picture did not fit in the first posts 5pic limitation, so i had to post it separately to show the TIM "footprint"
    Papusan and Mr. Fox like this.
  10. Mr. Fox
    Oh really? That must be only for the the GPUs install in the P7 machines. I have never seen those on a 1080 in a P8 machine.
