Silentmaxx laptops: could they be really less noisy than those from other resellers?
Discussion in 'Sager and Clevo' started by nesdnuma, Mar 21, 2017.
  1. nesdnuma
    nesdnuma Notebook Enthusiast
    Hello,
    The german reseller Silentmaxx offers Clevo laptops as silent computers.
    Thay say the case is dampened ("Dämmung des Gehäuses"). Any idea how they do it?
    Also, they say they use a passive power supply ("passives Netzteil"). What is it supposed to mean?
    Thank you in advance.
  2. Prostar Computer
    Hi
    Have you considered contacting them about this?
    Sound dampening is usually done by lining the chassis with a thin foam material. It seems unlikely they'd go to that much trouble on every system when they're not that loud to begin with; I'd inquire with them directly about it.
    Passive just means there are no fans integrated to cool the AC adapter.
    Mr. Fox and XMG like this.
  3. XMG
    XMG Company Representative
    @nesdnuma - does it definitely say that the laptops are "Dämmung des Gehäuses", or are they talking about the PCs?
  4. nesdnuma
    Actually it's in the FAQ and the FAQ is different for each range, so one would logically conclude that the laptops are indeed damped. Anyway I have asked them whether there's a specific damping. I'll let you know if I have any answer from them.
  5. Support.1@XOTIC PC
    Support.1@XOTIC PC Company Representative
    I'd be curious to see how they do this as well, and how much it actually helps on the noise levels.
  6. XMG
    Would be interested to see what they say.
    Customised fan profiles can help with the volume of the system, but AFAIK we are the only company that Clevo supports in doing this through the EC.
    If you only offer low power CPUs (they don't have K series for example) then you will have a quieter, but lower performing, laptop. It seems a little strange thay they say that in P870DM3 / P870KM the Intel graphics are passively cooled.........plus the FAQ you mentioned is the same for the whole laptop range.
  7. nesdnuma
    They do have the K series. See this one for instance.
  8. bennyg
    bennyg Notebook Deity
    If it's got a fan, it's not silent. And any amount of padding on the case will not make it silent so long as the noise from the fan has an unfiltered path to the outside via a grill.
    "Passive adapter" is just pure spin. Every Clevo already comes with one (or two) from every reseller worldwide. Most have an audible hum though ( so aren't strictly "silent" either.
    Show me a pic of a calibrated noise meter test showing 0dB (or even 3dB which is on their laptop page) lol.
    Mr. Fox likes this.
  9. franzerich
    franzerich Notebook Evangelist
    Hmm strange. Even for the Kanwa 555-M (Clevo W650KK1) they say "60% of the cooling is by passive cooling system". Passive cooling system? I wonder where's the space in this laptop for huge cooling ribs...
    :vbconfused:
    Also what happens if the CPU/GPU gets too hot? Will they just downlock and result in a framerate drop? (while an "active" cooling system would just make the fan spin faster?).
  10. nesdnuma
    By the way I got no answer from them so far...
  11. sicily428
    sicily428 Donuts!! :)
    it seems a clevo p751dm2-g
  12. tanzmeister
    tanzmeister Notebook Evangelist
    what do you mean? do you have special software for fan control?
