shareyour hel80 hot as mine
Discussion in 'Other Manufacturers' started by pcat, May 7, 2008.
  1. pcat
    pcat Notebook Enthusiast
    five screws? where?which?thank you!
  2. INEEDMONEY
    INEEDMONEY Homicidal Teddy Bear
    The heat is coming from the CPU. Only thing I can think you can do is clean the fan.
    If you look at your 1st picture, you have to remove the covering in the top right corner (the covering above "this area"). There are 2 screws holding it in. Once the covering is removed, you then have to unscrew the fan which is 3 more screws of the same size. Then clean the fan with compressed air and clean the vent the air gets blown out of.
    Let us know if this helps
  3. pcat
  4. INEEDMONEY
    Yes, pages 5-11 and 5-12 of the disassembly guide is what you're looking for. Steps 1-5 is all you need.
  5. pcat
    thank you!INEEDMONEY。
    i disassembly it and clean cpu fan and Radiator ,gpu Radiator 。rescribble heat conductive adhesive on。it is good now。
    but i don't find TV(RF) module and bluetooth module ,right speaker don't work(maybe something wrong with right)。
  6. INEEDMONEY
    Bluetooth module is under the hard drive. Once you take out the hard drive, you'll see the bluetooth. TV tuner should be next to your ram.
  7. pcat
    oh,my bluetooth module maybe stealn by dishonest trader 。:)
    Mr MONEY,you don't have TV module too?if not where insert TV tuner line ?
    Mr money,i want be friend with you。my msn is pcat126@126.com ,add me
  8. INEEDMONEY
  9. grbac
    grbac Notebook Deity
    I want to be a friend with money but it keeps going away from me. :biggrin: :D
  10. pcat
    but you can make friend with mr ineedmoney。
