shareyour hel80 hot as mine
Discussion in 'Other Manufacturers' started by pcat, May 7, 2008.
  1. pcat
    pcat Notebook Enthusiast
    my english is poor ,:eek: :eek:
  2. grbac
    grbac Notebook Deity
    Yes, I believe that is the hottest part.
    Whats your temperature?
  3. pcat
    EVEREST report
    cpu:48(118)
    1:48(118)
    2:46(115)
    gpu:46(115)
    hdd:39(102)
    :p :p
  4. pukemon
    pukemon are you unplugged?
    those temps are fine especially if they're under load. what's your idle and load temps?
  5. INEEDMONEY
    INEEDMONEY Homicidal Teddy Bear
    Those temperature seem to be about normal. The heat is coming from the CPU. Right now my CPU temp is 35 just sitting hear surfing the net. I clean out the dust at least once a month
  6. pcat
    3xs,when i paly Zhen Sanguowushuang Online Sc(one 3D online game) 30 mins,
    EVEREST report
    cpu:63(145)
    1:63(145)
    2:62(144)
    gpu:56(133)
    hdd:41(106)
    :confused: :confused:
  7. pcat
    yes,i buy hel80 just one week.
  8. spizzak
    spizzak Notebook Consultant
    My Hel80 got really hot (to the point where it was shutting off itself)... then I realized I needed to clean the fan out from dust lol now it runs much cooler. Maybe thats your issue but if you just bought it a week ago, which is what I beleive you are saying then that's probably not the problem and you're just not used to the heat.
  9. Locker420
    Locker420 Notebook Enthusiast
    I would second the fan intake and out take cleaning to repair heat problems. Even if only a week or two in dusty environment at high use can start to raise your temp. If you don't clean it regularly you will experience heat related shut downs if you game heavily.
    It's five screws and easy to do, takes about 10 minutes. Do it on the regular and your heat problems will be reduced.
    Peace,
    Locker
  10. pcat
    i buy this
    but paly warcraftⅢ one hour,my left hand is hot and sweat。touchpad left is pc PCMCIA 。i don't use ,why it so hot?
    is Radiator ?
