[SetFSB Auto Tool] - Automatic CPU overclocking utility
Discussion in 'Sager and Clevo' started by Audigy, Dec 11, 2008.
  1. Audigy
    Audigy Notebook Evangelist
    What is SetFSB?
    SetFSB is a program that makes possible control the PLL(Clock Generator) on your board, so you can control the FSB and PCI/PCI-E buses while in Windows. That way you can overclock your CPU and system memory too.
    What is SetFSB Automatic Tool?
    I decided to make this tool, because when you shutdown(to power off/standby) all the settings that you have made within SetFSB are lost. Then you need to re-enter and re-setting the FSB again.
    So with this tool you don´t need to do anything, it will set a predefined overclock automatically on systems boot.
    Because the M570RU´s clock generator resets on shutdown(standby) but keeps its settings when you restart(the power is not cut), this tool will automatically detect that situation an will not rise the FSB again.
    How to in 3 steps:
    1________________________________________________________________
    Download SetFSB from here: http://audigyfiles.com.sapo.pt/AutoTool/AutoToolInstaller.rar
    Extract and run the AutoToolInstaller.exe. Accept and click the install button. (It will create a folder with the SetFSB files on C:\)
    2________________________________________________________________
    Then download(below) the SetFSB Auto Tool Configuration and Auto Tool OC ON. Place the both .exes anywere you like, desktop, programs, etc.
    If you need to reset your CPU to the stock frequency, just download(below) the SetFSB Auto Tool OC OFF. Place it anywere you like, desktop, programs, etc.
    3________________________________________________________________
    Now, run the Auto Tool Configuration Utility. It will ask for the stock CPU frequency. Enter it on Mhz units. Then click [OK].
    Next it will ask for the Max multiplier of your CPU. Enter it. Then click [OK].
    Finally it will ask for the desired overclocking frequency. Enter it on Mhz units. Then click [OK].
    Example: For one Intel Core 2 Duo T7700
    Stock CPU Frequency: 2400
    Max Multiplier: 12
    Overclocked CPU frequency: 2900
    If you have problems knowing about any of these fields, try the Intel Processor Spec Finder Database.
    If you still have doubts, just ask here that I will gladly help you.
    Now, if you want to apply the overclock automatically to the CPU when your system boots up, just follow these 3 steps:
    Click Start -> All Programs -> Startup. Right click over "Startup", chose open/explore.
    Now that we have the Startup folder open, copy the SetFSBAutoToolOCON.exe to the Startup folder.
    Finally, check the Startup folder via Start Menu to confirm.
    _________________________________________________________________
    Make sure that you have selected the correct and funcional PLL/Clock Generator for your machine. (Clevos M570RU/71RU/72RU/73RU use the ICS9LPR363DGLF PLL).
    SetFSB Auto Tool Configuration - http://audigyfiles.com.sapo.pt/AutoTool/AutoToolConfiguration.rar
    This tool will configure your overclock profile. Just copy it to your desktop or any other place and double-click on it.
    SetFSB Auto Tool OC ON - http://audigyfiles.com.sapo.pt/AutoTool/AutoToolOCON.rar
    Every time your computers starts or you run this tool manually, the SetFSB Auto Tool will automatically apply the predefined overclock to your CPU. Remember to test first in small Mhz steps.
    One tray baloon will automatically pop up, warning you about the overclocking frequency that was applied to your CPU:
    If in the future your don´t want the overclock automatically applied on system boot, just delete the .exe from the Startup folder. If you want to set another overclock frequency, just run the Auto Tool Configuration utility.
    SetFSB Auto Tool OC OFF - http://audigyfiles.com.sapo.pt/AutoTool/AutoToolOCOFF.rar
    This tool will reset your CPU to stock speeds when overclocked. Just copy it to your desktop or any other place and double-click on it.
    Code:
    [B]Release Notes:[/B]
    Improvements over version 2.1:
    [I]- Added support for all CPUs(limited only by the support of your PLL)
    - Added support for 166 and 266Mhz FSBs
    - Added user friendly configuration with GUI support
    - Added the display of the overclocked frequency applied to the CPU[/I]
    12/12/2008 v3.1
    [I]- First public release![/I]
    * For version 3.2, custom overclocking profiles...
    Previous SetFSB Auto Tool releases
    Compatible with:
    - Vista x86/x64
    - XP x86/x64
    I hope that this little tool will be useful to you, as it was for me... ;)
    * I tested it exhaustively, but if you find any bug or error, please report it in this topic.
  2. Audigy
    I will upload the tool in a few hours... I´m only doing some final testings on various machines to make sure that everything is ok.
  3. yodawg
    yodawg Notebook Consultant
    how do i get the ppl without opening up my laptop
  4. Audigy
    First things first - you need to find YOUR PLL/clock generator among SetFSB's list in order to actually manipulate it. There are only two ways to find out your PLL:
    1. Open up your laptop, find it on the motherboard and then look at what it say it is.
    2. Instead you can just try with every PLL generator in SetFSB, until you get the correct one. The correct one will show your CPU frequency as identical to the one in CPU-Z. Find it via trial and error.
  5. sohail99
    sohail99 Notebook Consultant
    wow!! the most awesome OC tool nd programmer is back!!:D Awesome job!!:D
  6. yodawg
    has any1 already found the ppl for a t5750 or any1 know where i could search it online ?
  7. Audigy
    Thanks ;)
    I´m glad I can help!
    Remeber, the PLL is not CPU dependent... it is located on your motherboard, so it´s model/platform dependent.
    Try all the PLLs listed on SetFSB, thats the easiest way.
  8. Johnksss
    Johnksss Notebook Nobel Laureate
    this still doesn't work on the np9262 right audigy? even with knowing the pll?
  9. Audigy
    Unfortunately the PLL of the D901C has some kind of lock on the SMBus... leading to an impossibility of changing the FSB via softmod(PLL Registers).
  10. Johnksss
    they must have seriously knew something when making this model...:(
