Seriously E6520? (FN+SHIFT+1,5,3,2,4)
Discussion in 'Dell Latitude, Vostro, and Precision' started by Rykoshet, Aug 22, 2011.
  1. Rykoshet
    Rykoshet Notebook Deity
    Ok, pressing this combination, and then FN+R on my E6510 brings up the BIOS Thermal Options, allowing me turn off BIOS thermal management and run speedfan.
    On the E6520, the first combination seems to work, the CAPS LOCK key blinks for a second, but then FN+R does not work. Nothing seems to work actually.
    Any help, I need to use speedfan as it's constantly getting too hot!
  2. Dreamliner330
    Dreamliner330 Notebook Evangelist
    ? my e6520 is the coolest running laptop I have ever owned.
  3. ranranran
    ranranran Notebook Consultant
    Not when you're running LOTRo or something - my temp according to speedfan hits 80oC !!!!!!!!!!!!!!!!!!!!!!!!!
    I want thermal control too, but speedfan can only monitor, no adjustments work.
    ...and that key combination does *NOT* work on the E6520, as Dreamliner said. What is the key combination????
