Series 9 Problems After BIOS P09ABK Update
Discussion in 'Samsung' started by John Ratsey, Oct 30, 2013.
  1. John Ratsey
    Last week I updated my Windows 8 NP900X4C to BIOS P09ABK (which nearly bricked the computer but that's another story).
    Since then the battery had been sitting at 100% although I had re-enabled BLE (the BIOS updates always disable it). Today I ran the computer on battery for a short period of time and the charge dropped in the usual manner. However, when I reconnected the PSU the charge level jumped from about 96% (I can't remember the exact number) to about 76%. But the battery didn't charge back to 80% as BLE is meant to do. So I progressively drained the battery and checked at interval when the recharging is initiated and the critical point was 63.3%. (This is 79% of 80%). I've now turned off BLE and am letting the battery charge up so I can see whether the computer thinks that 80% is full.
    Has anyone else with the P09AB* family of BIOS seen any changed BLE behaviour?
    **Update**: With BLE turned off, the charge reached 79.1% before charging stopped. Something is broken.:mad:
    John
  2. John Ratsey
    Further update:
    I thought I would try to be a good citizen so I phoned up Samsung support to try to report that BIOS P09ABK seems to have unwanted side effects. I got through to someone surprising quickly and they proposed first doing a CMOS reset and then running the battery calibration.
    For the reset the person said first disconnect the PSU and then poke something through the battery disconnect hole and hold it down for half a minute (I told them this was the wrong procedure but they didn't want to listen). We then reconnected the PSU, went into the BIOS, disconnected the PSU and started the battery calibration (the battery charge was reported as 99%). I then gave them a few complaints about Samsung's fiasco of Win 8.1 support but they didn't want to listen saying it was all Microsoft's responsibility! I then said we might as well hang up given that it would take the battery a few hours to discharge.
    I then escaped from the calibration, disconnected the battery, did the CMOS reset by holding down the power button then plugged the PSU back in and started. This time the system was reporting a sensible battery charge level and %. Whether resetting the CMOS or starting the calibration reset the confused data is unclear. I'm currently draining the battery while using it and will complete the calibration once it is almost empty.
    John
  3. John Ratsey
    Further update: The calibration resulted in reported battery wear of 6%. That's actually more like 8% because previously the fully charged capacity was more than the design. Not impressive for 5 charge cycles.
    I'll do another calibration.
    John
  4. John Ratsey
    And after another calibration HWiNFO reports:
    Full Charged Capacity: 62900 mWh
    Designed Capacity: 62160 mWh
    Wear Level: 0.0 %
    Cycle Count: 6
    Which indicates a slight drop in the fully charged capacity. That BIOS update had caused confusion somewhere.
    John
    Dannemand likes this.
  5. Akhu117
    Akhu117 Newbie
    Does your Laptop works fine now? (I have the same model as you)
    Have you experienced issues concerning standby mode?
    After Bios update today, my 900X4C won't go in standby mode by closing screen, or by pushing power button :(
    I will post this on a new thread and / or in this thread.
    Thanks for help
  6. John Ratsey
    I think the battery of my X4C is OK now.
    I have my computer set to hibernate on lid close so I just checked what happens: Nothing. I hadn't previously noticed this problem because I tend to manually select hibernation. I've checked the power plan settings and they are OK.
    So this looks like another side-effect of the P08ABK BIOS update and I'll rename this thread to cover this issue. Someone else reported a similar problem which appeared to be the result of the Windows 8.1 update but I've not gone down that path yet. Perhaps their updating included the new BIOS.
    I'll check whether reinstalling Settings has any effect.
    John
  7. John Ratsey
    Reinstalling my previous Settings (2.1.2.0) had no noticeable effect.
    However, today SW Update offered me a new version of Settings (2.2.0.5) which went through several restarts to get itself working. The process included resetting my old power plans. Now that I've reconfigured the lid close action to Hibernate the computer hibernates again.
    Settings 2.1.2.0 has a few other quirks and changes, so I've given it another thread.
    John
  8. sabbasolo
    sabbasolo Notebook Guru
    I installed some updates today, including lan driver and elan driver. I have previously seen the loss of screen closing functionality since the bios update, but it is working again now. My settings is 2.1.0.0 and I haven't been offered anything else for my NP900X4C
    However the ELAN driver v11.7.18.2 doesn't seem to offer the reverse setting for two finger scrolling - it is driving me crazy!
    The registry settings I found in various places SC_Reverse_Enable doesn't seem to help
    ------------ EDIT
    In the folder of the downloaded ELAN driver, I found a program ETDAniConf.exe which lets you configure everything, (including many other hidden settings), and it seems to have worked. Reverse scrolling is now "disabled" in that program's settings, and works as it used to for me.
    Worth playing with - lots of cool settings in there.
  9. MinorOS
    MinorOS Newbie
    i installed the P09ABK Update on my NP900X3E and have many problems like no brightness fn funtion or wifi toggle (F12), BUT aftear read this and doing a CMOS reset everything is working again on Windows 8.1even suspend with lid function ! :thumbsup:
    i have:
    Setting 2.2.0.5
    Elan driver 11.7.10.4 ( i avoid the 11.7.18.2 since have the multitouch bug )
    Wifi intel driver 16.5.3
    Intel graphics driver 10.18.10.3304
    Win8.1 brightenss patch 1.0.0.1
    Sound Driver 6.0.1.7055
    i don't install:
    Lan driver
    BT driver
    thanks John for documenting this bios update
  10. SkuterPL
    SkuterPL Notebook Consultant
    But even if you open ETDAniConf, you will be having problem with 2 fingers like right button on mouse, I have it :/
