Series 7 NP700Z3AH Fan noise -abnormally loud?
Discussion in 'Samsung' started by motherfo, Apr 20, 2012.
  1. motherfo
    motherfo Notebook Enthusiast
    Hey all,
    Samsung sent me a NP700Z3AH after I shipped my QX411 back and forth numerous times.
    It seems I've inherited another laptop with issues. I've been browsing your forum the past few weeks and I decided to sign up and see what some of you think or if you are experiencing the same issue.
    I've included a video clip taken late at night in a quiet room so you can hear the idle fan noise. It seems like a constant whooshing sound even in silent mode. It seems like cooling would be an issue from the design and my unit only has a single fan compared to the larger laptops with 2. But macbooks have a similar design and are very quiet.
    New video recordings: 4-25-2012 record 01
    4-25-2012 Record 02
    4-25-2012 Record 03
    In the one video I ramp up the fans by running prime95. In one video I go from standby to on and allow you to hear the fan. Basically the issue is, in a quiet room, I can be 5ft away and still hear the fan or noise. Even with silent mode it's noisy. Is it the hard drive spinning or the fan?
    Old Link: http://dl.dropbox.com/u/9534475/Video%20Apr%2020%2C%2012%2029%2015%20AM.mov
    I also noticed my laptop was thermal throttling when I first got it. If I ran prime 95 it was hitting 95C and then dialing down the clock speed. Since then, I followed someones dis-assembly guide and ended up replacing the thermal paste with some I own. That seems to help. I've got some screenshots I can upload if need be. The unit now idles around 40-49C and when I ran prime95 It maxed out around 78-81C which is much more comfortable and kept the clockspeed up around 2.5ghz.
    Thanks all
  2. motherfo
    I've posted some updated videos to help get a response from everyone.
    Thank you
  3. Mobius 1
    Mobius 1 nͫiͤcͫeͤ
    what's the temperatures using HWinfo64?
  4. Jasman
    Jasman Notebook Consultant
    Yes. I just got one for my wife, and I'm sorry to say that it runs hot and the fans, in normal mode, just keep running. I wonder if it's a bad unit and if I should either return it or disassemble and use better thermal paste. I put it on quiet mode, with the fan running constantly at low speed, and it seems to be running up in to the mid- and upper-50-deg range when doing basically nothing.
  5. Ephelant
    Ephelant Notebook Consultant
    My S7 is basically silent when used for basic tasks (web surfing, MS Office work, etc.). I only hear the fan kick in when under significant load (gaming, mainly). Even then, it's not that loud.
    Sounds like you got a faulty unit (no pun intended).
  6. ultrah
    ultrah Notebook Guru
    the fan is running in silent mode too, but very silent, I can only hear it if I am very close to the notebook.(ssd)
    Theres seems to be a strange bug with the audio driver, sometimes there is white-noise-kinda sound coming from the speakers which I mistook for fan noise at first. This persists even after a reboot. If I play a loud sound for 1-2 seconds it disappears.
  7. motherfo
    Temps are the same as with HWmonitor. 45-50ish idle
  8. motherfo
    Same as hwmonitor 45-55 idle/basic usage.
    Did you get her the 14"? I disassembled and changed the thermal paste which helped fix the thermal throttling when running prime95, it also lowered my idle temps by about 10c, but it's still hot...and loud...ugh
    You have the 15" with two fans though?
    Do you have the 14"? Did you put an SSD in yourself?
  9. ultrah
    yes to both questions.
    the disassembly guide for the 15" model applies to the 14" version too
  10. motherfo
    Did it make your unit quieter?
    I can hear mine in a quiet room 5 ft away from the unit. Part of me is unsure if it's the hard drive or the fan noise.
    Also, does this white noise happen when the speakers are muted?
