Second hand ultrabook for engineer/programmer
Discussion in 'What Notebook Should I Buy?' started by cerbin, Oct 2, 2017.
  1. cerbin
    cerbin Newbie
    Previous Laptop is Thinkpad T410, it is so heavy and bad looking, I want to get some lighter and more efficient.
    General Questions
    1) What is your budget?
    Im not from USA so not sure with currency exchange but about 600-700$.
    Ultrabook; 13" - 14" screen
    3) Where will you buying this notebook? Poland.
    a. Like: Thinkpad, Dell
    5) Would you consider laptops that are refurbished/redistributed? Yes
    Programming, including working with integrated development environments, creating websites, having opened few or dozen tabs in Chrome.
    Outside and inside, in college or outside in some Cafe.
    No
    4-5 hours would be great, I want to buy new battery.
    No
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    Linux, Ubuntu.
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    hd/fhd, but preferable fhd
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    matte, ips best I think
    Build Quality and Design
    Not so important but would avoid something like my previous thinkpad design
    In online shop
    few years, like 2-3 would be nice.
    Notebook Components
    SSD would be nice, 128GB, but I can buy it separately.
    18) Do you need an optical drive? If yes, a DVD Burner, Blu-ray Reader or Blu-Ray Burner? No.
  2. tesm1th
    tesm1th Notebook Consultant
    ThinkPad 13?
    cerbin likes this.
  3. Charles P. Jefferies
    Hi, welcome.
    The ThinkPad 13 is a good suggestion.
    Also look at the Dell Latitude 14 5000 series (E5470, or the newer 5480).
    You may want to get a refurbished notebook. Try our guide to outlet shopping.
    Charles
    cerbin likes this.
  4. cerbin
    cerbin Newbie
    After some rethinking I resigns from 13 inch screen, and will go into 14.
    This Dell E5470 is great but unfortunatelly its resolution is hd, I am aware that this will not enaugh. After some research I found these models:
    Dell Latitude E7440 / E5450 / E6440 all with i5-4300U CPU
    HP 840 G2
    Would you recommend some of these models?
  5. Charles P. Jefferies
    The E5470 was available with a 1080p display. It might be hard to find, though.
    I use an E7440 for work. It's nice, but old. Look for an E7450. (Something with a Core i5-5XXX or Core i7-5XXX "Broadwell" CPU or better.) Or an E5450.
    HP EliteBook 840 is of good quality. You can also try the ProBook 640, it's like the Dell Latitude 5000 series in quality. The EliteBooks are like Dell Latitude 7000 series.
    Charles
  6. cerbin
    cerbin Newbie
    Hi Charles,
    after some research I have found interesting offers:
    Dell E5470 i5-6300U 8GB DDR4/128GB SSD, FHD
    Dell E7450 i5-5300U 8GB/256 SSD FHD
    Both have a year warranty (E5470 have Dell warranty until October 2019 but it may be some problems with that because it is from another country, so the seller gives 1 year).
    Both models are in the same price.
    Wchich one would be better for me? Could you please help me? Thanks :).
  7. Charles P. Jefferies
    Ah, tough choice! The E7450 is going to have better quality. There is very little difference in performance between the Core i5-5300U and Core i5-6300U. Plus the E7450 has 2x as much storage.
    I'd go with the E7450 ...
    Charles
  8. cerbin
    cerbin Newbie
    Thanks for the reply :).
    One last thing. If the warranty would be available for two years for that dell E5470 should I take it then? To be honest, 128GB is enaugh because I will only work on this laptop, I have PC at home. In addition, E5470 has DDR4 Ram. So taking everything into account is 2 years + better ram better than lower storage and 200 grams heavier laptop? Regards.
