Second Alienware 17 R4, Shutdown Problem
Discussion in '2015+ Alienware 13 / 15 / 17' started by QrafTee, May 29, 2017.
  1. QrafTee
    QrafTee Notebook Enthusiast
    I'm running into an issue with my replacement Alienware 17 R4. The first one I received had a Brazilian power supply and a stuck pixel; it was replaced with this one. Before I head to Dell (or go through the long process of reinstalling the OS) again, I was just wondering if anyone has ran into this and fixed it.
    When I shut down or restart the computer, it hangs at the end of the shut down. All apps shut down, OS shuts down, keyboard LEDs are off, but the Alienware power button remains on. I have to hard shut down at the end. I've tried using the Troubleshoot Windows Update feature, turning off Fastboot, and trying a different power supply. But no go, it just randomly hangs at the end of a shut down.
  2. Vasudev
    Vasudev Notebook Prophet
    Any third party Anti Virus? Worth checking the quarantine of your AV.
  3. QrafTee
    No, fresh install onto the NVME drive. Only AV is Windows Defender.
  4. MogRules
    MogRules Notebook Deity
    Mine does it once in awhile and I can't figure out why. 80% of the time it shuts down as expected. The other 20% it takes longer, maybe 3-5 minutes to complete the shut down.
  5. Fajo
    Fajo Notebook Consultant
    I understand people say they have shut fast boot off. But if you have not, it might be worth it when upgrading drivers or doing first time installs. I have had fastboot more then once screw the system up when a fresh format was done. I turn it back on after all the drivers are installed rebooted and working fine.
    Vasudev likes this.
  6. Vasudev
    @QrafTee: Disable Hibernate using powercfg -h off in elevated command prompt.
