SD Slot on CF-19FJGAAAM
Discussion in 'Panasonic' started by gijoe4us, Feb 11, 2018.
  1. Shawn
    Thats fine.
    The step by step upgrade path usually eliminates basic driver issues.
  2. gijoe4us
    gijoe4us Notebook Consultant
    Okay, downloaded the Win 8.1 and Win 10 Pro 64 Bit versions. I do have both the 8.1 key, as well as my Win 10 key. Luckily I have not installed too much on this 19 FJ sled.
    I will start with a total, clean install of win 8.1 with Mk4 drivers and see what happens. Next I'll do same if it does not get SD Slot up and running under Mk5, then Mk6, and then I will go back to Mk3 if all fails. If ALL fails, I'll re-image, and do a Win 10 64 bit install and see what happens....
    I love having the extra 19, and 5 operating systems (32 and 64 Bit) to test on while waiting for my "parts" machine from Canada!!! Keeps me mind working fully!!!
    Anyways, Toughbook and toughasnails nailed it!!! Do research!!!!! Ask questions, not hacks, cracks, serials and passwords!!!
    Shawn likes this.
  3. gijoe4us
    After all the researching, I have wiped the SSD and re-installed Win 7 Ult 64 Bit. Then I installed the Pani Driver Package for Win 7 64 Bit MK IV. All of the buttons, SD Slot, EVERYTHING, is working perfectly. Somewhere in the Win 8.1 and/or Win 10 on a MK III, it does not like any of the other driver packages from Pani and the MS ones don't work.
    What is very interesting, is that when I look at my MK IV driver for the SD Storage controller, it shows it as "migrated". The MK IV came with Win 7 32 Bit. I installed a 64 Bit being a MS TechNet guy and then the Pani drivers. I then went to 8, and then 8.1, and finally to Win 10 as an MS Win 10 Insider. Doing this process on the MK IV, everything still works fine.
    I think something in the hardware on the MK III will not update to a newer driver, thus not recognizing the fact that an SD slot is installed.
    Again, thanks for input!! Panasonic does recommend Windows 7!!!!
    Shawn likes this.
  4. gijoe4us
    I think this may be the way to get SD card to work on Mk II version with Win 8.1. I have 7 n that one and I'm not playing with it for the time being..........
    How to Disable Driver Signature Enforcement in Windows 10/8/7 64-Bit
    May 4th, 2015 by Admin Leave a reply »
    In 64-bit operating systems starting with Windows Vista, Windows will load a kernel-mode driver only if the driver is signed. It was designed to prevent unsigned device drivers (or kernel modules in general) from being loaded and executed. After installing an unsigned device driver, it will always result in a blue screen of death during the startup process.
    The problem is that many devices ship with unsigned drivers. Today, we’ll show you 2 methods to disable Driver Signature Enforcement in Windows 10, 8, 7 (64-bit) so you can then install / load unsigned drivers without problems.
    Option 1: Disable Driver Signature Enforcement Completely
    Open a Command Prompt with admin privileges. In Windows 10 or 8, just press the Windows key + X and then select “Command Prompt (Admin)”.
    Type in the following command and press Enter.
    bcdedit /set testsigning on
    You should receive “The operation completed successfully” message.
    Close the Command Prompt and restart your computer. From now on, you will be able to install or run any unsigned driver without problems.
    If you need to enable the Driver Signature Enforcement again, run this command instead:
    bcdedit /set testsigning off
    Shawn likes this.
  5. gijoe4us
    Another issue with being in test mode, is as soon as you set it back to "non-test" mode, it resets all the drivers. Leave it in "test" and remove the watermarks, spelled out below. I did it and it worked flawlessly!!!
    [​IMG] OPTION TWO [​IMG]
    Remove "Test Mode" Watermark without Turning Off Test Mode
    1. Go to the Softpedia link below, and download My WCP Watermark Editor.
    Download My WCP Watermark Editor 1.1.0
    2. Run the downloaded My_WCP_Watermark_Editor.exe file.
    3. If prompted by UAC, then click/tap on Yes.
    4. Do step 5 or 6 below for what you would like to do.
    5. To Remove Watermark
    A) Check the Remove all watermark box at the top, click/tap on Apply new settings, and go to step 7below. (see screenshot below)
    6. To Restore Default Settings
    A) Click/tap on Restore default settings, and go to step 7 below. (see screenshot above)
    7. When finished, click/tap on Done, Click for reboot, after reboot reset your wallpaper to see all change. (see screenshot below)
    8. When your computer finishes restarting, reset your wallpaper to see the change.
    Shawn likes this.
