Screen top panel removal help.
Discussion in 'HP Business Class Notebooks' started by Padraig O Cuinn, Dec 22, 2017.
  1. Padraig O Cuinn
    Padraig O Cuinn Notebook Consultant
    Hey there everyone and anyone. Does anyone know of or have info on taking off the top panel on zbook 17 g3 and g4, due to a certain 3 year old I have to switch them over haha. This is the dreamcolor screen 4k
  2. tamarinde
    tamarinde Notebook Consultant
    Had a look at a broken G3 I have lying around and it doesnt look like the top will come off.
    Inside I could not find any way to seprate the top
    Tried to wedge it open but it felt like it would bend the metal
  3. Padraig O Cuinn
    It must be able to because a technician was able to replace a screen on my old one. I'm going to keep trying. See if you can come up something too if you have the time tam
    Sent from my SM-G950F using Tapatalk
  4. tamarinde
    Sorry misread something... Thought you meant palmrest top
    Screen is rather easy.
    Undo the antenna's and the screen cable then undo the screws of the hinges.
    The front bezel will come off easily, it has little hooks on the outside every 3cm or so.
    Inside sides have a sticky strip.
    So start on the top by either pulling the bezel or use a small screwdriver slightly to the outside of the mic holes
    Not sure if it works from the bottom because my hinges are not loose at the moment
    Source of pictures here: http://forum.notebookreview.com/threads/hp-zbook-17-g3-owners-lounge.788223/page-5
  5. rahasyavadi
    rahasyavadi Notebook Consultant
    Padraig, when you do open this assembly, would you please record and post for us the identification data (brands, part numbers, and/or such) of the screen, cable from screen to color board, color board itself, and cable from color board to motherboard?
  6. Padraig O Cuinn
    Yes no worries rah.
