Screen replacement options on P670?
Discussion in 'Sager and Clevo' started by VetteV12, Mar 12, 2017.
  1. VetteV12
    VetteV12 Notebook Enthusiast
    Does anyone know if there's a better, higher quality, screen replacement for the P670HS? I'm considering one of these for daily use but the screen is major turn off. I'm ok with 1080p, but with an 8bit color gamut and 120hz, somehting like the MSI GT72VR 7RE has in it. I would prefer the 4k screen that is offered on the P775 that has 100% adobe RGB, but I'm not sure it'll work. Has anyone tested out a different screen in these or does anyone know the specs for the connector?
  2. Meaker@Sager
    What screen have you got?
  3. VetteV12
    Not sure the exact model number of the screen, but whatever it comes standard with. No company offers a different screen for it so I want to try and find one that I can install myself.
  4. Meaker@Sager
    It will work with any 30 pin eDP panel that physically fits in the machine though you will loose G-sync.
  5. VetteV12
    Why would I loose Gsync if the panel I replace it with is Gsync capable in other laptops?
    Are you sure that any 30pin eDP will work? The first laptop I looked at was the Tornado F5 from Eurocom and was told that not all 40pin eDP panels will work due to the connectors being slightly different and why they couldn't upgrade me to a SHARP IGZO panel...unless they lied to me:mad:
  6. Meaker@Sager
    The nvidia system is setup so that each specific GPU/screen combo is white listed. Sometimes a BIOS update is needed if a later version had that screen as an option.
  7. Chris S
    Chris S Notebook Enthusiast
    It's a shame the bios mod can't be purchased separately.
    It really is ridiculous with Nvidia white listing it to different monitors.
  8. Meaker@Sager
    They tend to be ultra protective over their features like that.
  9. Chris S
    Well if it's only a matter of white listing, it's done to control the market at higher tiers.
  10. Meaker@Sager
    Nvidia's argument is if their technology and name is on a feature they want to validate and ensure a consistent experience no matter the supplier.
    Prostar Computer likes this.
