Screen Replacement for Predator 15-G9-593
Discussion in 'Acer' started by Quaternum, Jul 11, 2018.
  1. Quaternum
    Quaternum Notebook Enthusiast
    Hi,
    My question is simple : My panel is a AUO60ED ( 60Hz panel Gsync), can we put to this laptop a 120Hz panel ?
  2. B0B
    B0B Notebook Deity
    Of course you can. The AUO42ED should work perfectly.
    I install 120hz panels in laptops quite often. Just put one in a Nitro 5.
    Quaternum and ellalan like this.
  3. Quaternum
    Does I need to take out the battery before replacing the screen ? ( there is no content on Youtube on how to replace a Predator 15 screen xD)
  4. B0B
    B0B Notebook Deity
    I have done the job with the batter plugged in and unplugged.
    If you’re in a high static environment then take proper precaution.
    While I don’t have a tutorial on the Predator I have several on other machines. The procedure will be the same on my tutorials as it is on your Predator.
    It takes about 10-15 minutes to do if it’s your first time.
    Quaternum likes this.
  5. Quaternum
    Thanks you for your help :)
  6. sicily428
    sicily428 Donuts!! :)
  7. Syns
    Syns Newbie
    I plan to buy acer predator 15 with 1070, and what do you think about the thermal in this laptop? Is it good to handle 1070 and the cpu?
  8. B0B
    B0B Notebook Deity
    If it’s the G series it’ll be solid after a repaste.
    The GPU isn’t the issue.
    The cooler is chincy but the fans are thick and move a good bit of air. Plus they scavenge a good bit of air since the chassis is pretty thick and has some open spaces inside. At least that was the case on the 17”.
    But you will be very disappointed thermally out of the box.
    The difference with new TIM on the 17” models I used in the past was higher than any laptop I tested so far.
  9. Quaternum
    Nah, I think it will be nice thermally speaking if you use vertical sync... But yeah with a new paste it will be perfect
  10. B0B
    B0B Notebook Deity
    I’ve had three of them. Using vertical sync to improve thermals, it’s gonna be very title dependent.
