Screen replacement CF-19
Discussion in 'Panasonic' started by ADOR, Feb 21, 2012.
  1. ADOR
    ADOR Evil Mad Scientist
    For Christmas I got a CF-19 Mk1 for my girlfriend for her a spare/travel computer. She loves it. He oldest son is Autistic and had been borrowing it to play on every day. He usually does very good and doesn't mess with anything. She wasn't in the room at the time so she doesn't know for sure how he tripped but he wound up dropping her CF-19 and busting the screen. For right now I have two spare CF-19's and just going to swap her battery and harddrive over while I see what I need to fix this one.
    Will a screen off of a CF-18 work or will it be CF-19 only item?
    I will be fixing up him his on CF-18 so maybe he will leave his mothers computer alone as her dell laptop has developed problems and she has had to depend on the toughbook more for her school work.
  2. onirakkiss
    onirakkiss Notebook Deity
    I think Theo had created an CF-18 with cf-19 screen, so it should be exchangeable...
  3. kevin1162
    kevin1162 Notebook Guru
    i replaced my CF-18 LCD and touch panel with an OEM replacement kit for a CF-19. Should be Do-able
  4. bt43a
    bt43a Notebook Enthusiast
    I got a CF-19 Mk1 with broken screen and replaced the screen with one out of a CF-18 Mk2.
    It works, but maybe it is a bit darker.
  5. toughasnails
    Yes it was Teo but he used the whole top from a 18. But its not that easy...rewiring and changing a few things.
    I bought one of these half breeds on ebay by mistake...knew some was missing...the speaker :eek: ...that was when I realized it was a 18 top. The guy tried to rewire the video line to get it working but messed it up so now it needs a new one. I have so many things on the go never got around to working on it so it just might end up on ebay
  6. ADOR
    Ok. I still have about 5 to 6 CF-18's I haven't put together yet so it looks like I will be stripping one out for parts and selling off the rest cheap. I was running out of batteries and caddy's anyways, lol. Just got the storage cabinet I wanted. Had a long drive to get it but all real wood, no particle board crap. I three more big boxes to go through and about 10 more computers to get rid of.
  7. ohlip
    ohlip Toughbook Modder
    I can confirmed that the cf-18 LCD is compatible with cf-19 but make sure it does come from atleast on CF-18MK4 or MK5 to give you the same brightness. Don't use on the MK1 coz it give a rainbow effect on the ts glass.
    Same also with digitizer unit. The digitizer panel aso the same It means that you don't need to transfer the digitizer panel from cf-19.
    Good luck
    ohlip
  8. toughasnails
    FYI : For over 28 years I have worked at Flakeboard making a very good living I might add, can you guess what we make...:rolleyes: :D .
  9. ADOR
    Hopefully the good thicker particle board that has some weight to it, most places around here have went with that thin light weight stuff most of the time it won't make it the ride home in one piece.
  10. mnementh
    mnementh Crusty Ol' TinkerDwagon
    Well, commonly available there's LDF, MDF, HDF and Masonite; all of which have their strengths and weaknesses. There ARE Waterproof versions as well; just not commonly used in furniture as the chemicals can be toxic and stain.
    MDF is the material of choice for building speaker enclosures due to it's high rigidity-to-weight ratio and excellent resistance to harmonic resonance; of course, once you get a good design, you can always make it out of hardwood but the cure time for the wood is a real pain in the tuchus. There's a reason those speakers cost a fortune, and the improvement over MDF is still 95% aesthetic, 5% sound quality.
    Yes, I've burned up a router or three and more than a couple table saws making speaker enclosures for pretty much anything you can imagine. ;)
    mnem
    I love the smell of MDF dust in the morning; smells like... THUMP!
