Screen Quality vs Resolution
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Melody, Jan 23, 2012.
Screen Quality vs Screen Resolution
  1. Screen Quality
    42.9%
  2. Screen Resolution
    57.1%
  1. Melody
    Melody How's It Made Addict
    Couldn't find a thread on a first search so figured I'd make one! :p
    So easy question: what would you value more (assuming you couldn't strike a proper balance between both or have both): Screen quality or Screen Resolution?
    Would you rather have a good quality screen but with poor resolution (so either WXGA or even a 4:3 screen) or get a poor quality screen but with a good high resolution (so WUXGA or something)?
    You can discuss the case with laptops or with external monitors! :D
    I personally feel like I could live with an "ok" screen (as in the mediocre run of the mill screens most computers use) if it had a good resolution. To me, the quality of the screen is mostly a plus and I need work space to get things done. I do lots of graphics work too but for most of the stuff I'd need "quality", I would most of the time not be working on my own setup anyways.
    What are your preferences?
  2. Nick
    Nick Professor Carnista
    Quality over resolution for me.
    My HP 8460P has 900p screen, but the quality is horrible and makes my eyes bleed.
    My previous X460DX had a 720p screen, but it had way better quality and didn't make my eyes bleed.
  3. jrwingate6
    jrwingate6 Notebook Deity
    You forgot to add another option. I would rather have a average quality display with a 1080 resolution any day than a high quality display with a 720 resolution.
  4. Tsunade_Hime
    Tsunade_Hime such bacon. wow
    I'd say both are correlated as most low resolution panels are awful, while ALOT of high resolution panels offer something like RGBLED, better viewing angles, better contrast. So in a sense, higher resolution is important as it almost always means a better panel. I can say the WUXGA RGBLED panel in my R2 is one of the best, and still 16:10.
  5. tijo
    tijo Sacred Blame
    Voted resolution, but there is a minimal screen quality i need though. That being said, Tsunade is right, even the glossy wled panels are usually much better quality for higher resolution, there are always exceptions, but it seems that panel manufacturer assume that when you put a 720p panel in a laptop, all you want is something cheap while when you go for higher resolution panels like 1080p, you expect a minimum of quality with the higher resolution. That is speaking of standard consumer grade notebooks of course. I also prefer having more desktop real estate, now, i'd probably have problems settling for less than 1080p on any panel 17" or larger. The 1440x900 res on my 15" N50 is ok, but i wouldn't get anything lower on 15".
  6. Melody
    Well yeah there's a correlation but I meant if you had to choose one or the other.
    Like for example when I was browsing for an external, for the same price bracket I could for a lower resolution 4:3 from the old Dell Ultrasharps or a newer larger 1080p LCD but regular panel so I wondered which mattered to me more. I still haven't gotten anything though :p
    Idk, to be honest I can tolerate a "regular" quality screen as long as it's not godamn awful :p Just calibrate it ok and it's good enough D: Like I said, if I have any important stuff that requires precise color calibrations I'll more than likely to go my printer's (the guy not the machine) office and work it out there to avoid any unpleasant surprises D:
  7. 5482741
    5482741 5482741
    My 16F2's screen is easily superior to my M860ETU's screen, quality-wise; but with its lower resolution, I definitely prefer the 1920x1200 screen to it.
    The higher-resolution screen simply allows me to display more on it at once; which I think is much more valuable.
  8. Tsunade_Hime
    I think it also depends on what you do with your notebook. People who code, browse emails, Excel will prefer a higher resolution and a lower screen quality as those value vertical pixels more than anything. However if you use Photoshop or do CAD, you'll want a better quality screen, though high resolution is nice. OR you can buy RGBLED IPS and just have the best of both worlds. :p
  9. redrazor11
    redrazor11 Formerly waterwizard11
    I'd rather have a good quality panel. If I need more resolution, I'll just hook it up to something else.
  10. MidnightSun
    MidnightSun Emodicon
    There's a correlation between the two. But, say, if I were to choose between a 1366x768 IPS versus a 1600x900 TN, I would immediately go for the latter. A 1920x1080 TN in the same size would make it a no-brainer.
