Screen flickering problem with Clevo P950HP6
Discussion in 'Sager and Clevo' started by Shadow Cloud, Jan 11, 2019.
  1. Shadow Cloud
    Shadow Cloud Notebook Consultant
    Oh boy I wonder if I mess up something because it feels like the fan(near the display cable) is running more constant now. This piece(circled in red) here is now slightly lifted up when I was re-seating the display cable. Could it be due to that?
  2. Meaker@Sager
    Those are the CPU cooling fins. If the heatsink is not sitting right then the CPU could be making poor contact to the heatsink. You could check by removing it and taking a picture of the pattern on the CPU and contact point on the heatsink left by the past.
  3. Shadow Cloud
    I guess the issue I have is how do I put the heatsink and CPU cooling fins back to their original positions since they seem to be permanently lifted?
  4. Meaker@Sager
    It would suggest the heatpipes are bent or the thermal pads are not sitting right.
  5. Shadow Cloud
    Is there any of kind of paste to hold it back in place? Like should I be using IC Diamond? When I was putting in the new cable. I also took out the fan to clean it a bit and wonder if it's because of that I have this loud fan problem. I've attached pictures of my new issue.
    http://imgur.com/gallery/RZYTZ0X
  6. KevC123
    KevC123 Newbie
    Hi, I am facing the same problem and I would like to know how did you open the back and what exact cable did you reseat to fix the problem. Thank you in advance!
  7. Shadow Cloud
  8. KevC123
    KevC123 Newbie
    I will try reseating the cable first, to see if the problem can be solved this way. Thank you!
