Screen flickering problem with Clevo P950HP6
Discussion in 'Sager and Clevo' started by Shadow Cloud, Jan 11, 2019.
  1. Shadow Cloud
    Shadow Cloud Notebook Consultant
    Below are the examples of the screen flickering issue:
    https://gfycat.com/WetWarpedChupacabra
    https://gfycat.com/InfiniteVacantBarasinga
    My laptop has two display drivers: Intel HD Graphics 630 and Nvidia Geforce GTX 1060. When I plug my laptop into another screen, the 1060 is activated and I notice no flickering options. This makes me think the problem is related to the Intel Graphics adapter. Even more so when I use Nvidia Control Panel and tell it to use the 1060 on FireFox(which sometimes cause the issue).
    I have downloaded the latest driver from December 2018 and still have this problem. What are my options? I'm on Windows 10 just to note.
  2. Vasudev
    Did you try adjusting the screen hinge and see if it fixes the issue. If it doesn't, use DDU to remove intel driver and install latest one.
  3. Shadow Cloud
    How would I go about adjusting the screen hinge?
  4. Vasudev
    Just nudge the screen from behind a gentle tap. Or you can adjust the screen with lower angles to see if it fixes flickering.
    75% I think its a driver issue and 25% a hardware issue.
  5. Shadow Cloud
    Okay I tried adjusting and uninstall and installing new Intel drivers. So far everything seems good aside from one instance of a quick flash so I guess for now I"m good.
    Vasudev likes this.
  6. Vasudev
    Great. So it was a driver issue?
  7. djsubtronic
    djsubtronic Notebook Evangelist
    I have this issue too sometimes and someone else had a detailed thread. Not sure if it's the same but it could be the display cable. Whenever I readjust the cable, the issue goes away... for a while.
    Vasudev likes this.
  8. Shadow Cloud
    I think so. So far so good.... I hope.
    Vasudev likes this.
  9. Meaker@Sager
    If you want to secure a cable use kapton or electrical tape over it to help.
    Vasudev likes this.
  10. Shadow Cloud
    How did you go about readjusting the cable?
