Scratch and dent or refurbished
Discussion in 'Dell' started by msfix, Dec 18, 2017.
  1. custom90gt
    custom90gt Notebook Deity
    I guess I'm confused about your issue here.
    1. Refurbished typically means they had to replace components. Dictionary.com defines it as "to make neat, clean, or complete, as by renovating, re-equipping, or restoring." Out side of restoring the operating system it is likely the same components.
    2. You ordered a scratch and dent computer which is a previously used or canceled order. Were you expecting it to be a factory blemish? I don't think any company sells factory blemishes when you can replace a cover for 50 cents.
    3. You likely saved a significant amount of money ordering scratch and dent, didn't it seem like there was some "catch" to that?
    Good luck with your new system
    alexhawker likes this.
  2. alexhawker
    alexhawker Spent Gladiator
    +1
  3. msfix
    msfix Newbie
    It used to be that "scratch and dent" referred to new products that had never been used, only physically marred. Home Depot, for example, sold new appliances at a deep discount if they had scratches or dents. I mistakenly thought that Dell used the same definition. My mistake.
    Background: In 2015 I bought a new Inspiron which lasted 18 months. After 5 motherboards were replaced, I insisted on another laptop. They sent me a refurbished Inspiron which has had a series of problems and is no longer functioning. But I like Dell's laptops, and unfortunately thinking scratch and dent was new, I ordered a latitude which I learned is another refurbished. This has been a learning curve for me. I hope I explained this okay.
  4. custom90gt
    No your reasoning makes sense, but I don't know when scratch and dent has ever been a term for factory blemish in the computer world. I've been ordering scratch and dent computers for many years and most of them were customer returns according to my IBM/Lenovo/Dell reps.
  5. msfix
    msfix Newbie
    I'm not familiar with the computer world. I'm just passing through on my way to purchasing a piece of equipment necessary in my line of work. I'm a retired bakery owner, writer, and teach baking, and the business of baking. (So if you have any bakery/business questions, I may have some answers.)
    Thank you everyone, for your help.
    custom90gt likes this.
