Schenker XMG p407 Screen flickering/Cable reseating
Discussion in 'Sager and Clevo' started by Etesian, Feb 5, 2019.
  1. Etesian
    Etesian Newbie
    Greetings,
    posting because I have the same issue as described here. Flickering does change when I move my screen, so I'm assuming it's the same cause too, a loose cable in need of reseating. So I've got 2 questions:
    1) How would I go about reseating the cable?
    2) Would doing this affect my warranty in any way? I DO have a warranty, but I'd have to send this laptop out of the country, which took 2-3 months with my last laptop.
  2. Prostar Computer
    You'd have to remove the screen, which requires removing the LCD frame/front bezel. Whether or not it risks your warranty is a question for your seller. From there, you'd just be removing the cable and re-inserting it, and re securing it with tape.
  3. Meaker@Sager
    XMG might guide you through it or want to look at it.
