Satellite a215: Screen goes funky purple, pink and green when tilted
Discussion in 'Toshiba' started by EinarO, Sep 26, 2008.
  1. EinarO
    EinarO Newbie
    Hi, does anyone know what my problem is. The screen on my Toshiba satellite A215 goes funky purple, pink and green when tilted back beond 110°, the image gets distorted in that way altough you can still se what is going on on the screen. It workes perfectly before it´s tilted back that much.
    Thank you in advance
    Einar
  2. Everway9
    Everway9 Notebook Consultant
    Hi, Its probably a loose connection somewhere. If not, how old is the laptop? and if under 1 yr old you could contact Toshiba and see if they will repair it for you.
    P.S is the screen tight when you push it back or is it loose
  3. EinarO
    EinarO Newbie
    The loose connection is also my guess too but I want to get second opinions before I take it apart. The screen is firm when pushed back.
    it´s just over a year old :(
    Thank you
  4. Jstn7477
    Jstn7477 Sam I Am
    It's probably a loose LCD cable if you turn the display and it magically comes back to life. It is a pretty simple fix.
    -J.B.
Similar Threads - Satellite a215 Screen
  1. ablex
    463
