SanDisk Extreme Pro SSD 10 year warranty!
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Bullrun, Jun 8, 2014.
  1. Bullrun
    Bullrun Notebook Deity
    Due out June 12, 2014
    SanDisk Extreme PRO Solid State Drives (SSD)
    240GB, 480GB and 960GB. That's right a 1TB
    What's the 30% OP math tilleroftheearth or RCB? :p
    But get this, 10 year warranty!
    NewEgg has the 960GB priced at $600 480GB at $370 and the 240GB at $190 for pre-order.
    Newegg.com - SanDisk/Internal SSDs
    240GB
    Seq. Read 550 MB/s
    Seq. Write 520 MB/s
    Rnd. Read 100K IOPS
    Rnd. Write 90K IOPS
    480GB & 960GB
    Seq. Read 550 MB/s
    Seq. Write 520 MB/s
    Rnd. Read 100K IOPS
    Rnd. Write 90K IOPS
    Advertised Sequential R/W and IOPS are higher than SEII
    AnandTech announcement with a PCMark 8 Consistency Test graph. http://www.anandtech.com/show/8110/computex-2014-sandisk-announces-extreme-pro-ssd
    I can guess who the 500GB competitor is. :D
  2. Marksman30k
    Marksman30k Notebook Deity
    Ah but does Sandisk shoot their SSDs with high energy particles from a particle accelerator? :p
  3. HTWingNut
    HTWingNut Potato
    According to their graph no OP should be required.
    saturnotaku and alexhawker like this.
  4. alexhawker
    alexhawker Spent Gladiator
    I think the 480GB SE II just dropped to $229.99 on amazon.
  5. Tinderbox (UK)
    Tinderbox (UK) BAKED BEAN KING
    Is failure due to high write to the flash exempt from the warranty, 10 years is a long time, how long does mlc flash memory last.
    John.
  6. npaladin2000
    npaladin2000 LOAD "*",8,1
    With those sizes they're probably already overprovisioned, looks like by 6% if the actual NAND sizes are the typical 256, 512, and 1024 GB. Wonder why they skipped the 750 GB class?
    10 year warranty is a great idea, based on standard desktop use cases and MLC NAND endurance there should be no issues with write lifetime during that time. Still like to see the fine print, I'm assuming there's a clause in there to protect them from someone who throws an excessive amount of writes at the thing. It does say the warranty is limited, but I couldn't find the text of if.
  7. saturnotaku
    Probably too little demand for it. It appears that Samsung has quietly dropped the 750 GB 840 EVO while they continue to sell the 500 GB and 1 TB versions.
    Balderdash.
    You must continue to over provision any and all SSDs you own. To 90%, or more if possible. Real works demands it.
  8. HTWingNut
    HTWingNut Potato
  9. Tinderbox (UK)
    My Plextor 512gb ssd does not use over provisioning it formats to 476gb free off the 512gb that difference is just for the FAT right?
    Also the Plextor SSD app does not offer an over provisioning option.
    John.
  10. HTWingNut
    HTWingNut Potato
    No, that's just the decimal to binary conversion.
    512000000000 bytes / 1073741824 binary bytes ~ 476.8GB
    And you can OP by just creating a partition then deleting the partition using disk manager or disk part command or your favorite partition manager.
