Samsung Series 7 Chronos NP700Z5A Disassembly Guide
Discussion in 'Samsung' started by yknyong1, Dec 16, 2011.
  1. yknyong1
    yknyong1 Radiance with Radeon
    Guide can be used on the Z7 series too, but screw positions may vary.
    Beware of easily stripped screws, make sure to use the correct size screwdriver!
    1. Remove the screw in red circle, then take off the RAM cover. Beware of the fragile plastic tab of the RAM cover.
    2. Remove the 10 screws in the green circles.
    3. Proceed to slide a plastic card to remove the bottom cover. Recommended to start from each side of the hinge, and meet at the trackpad. Caution advised for fragile plastic tabs.
    Bottom cover when removed.
    hohum likes this.
  2. yknyong1
    4. Remove the screws in the order shown, from 1 to 11.
    5. Unplug the fan cables labelled 12 and 13.
    6. Remove the heatsink and thermal paste.
    hohum likes this.
  3. yknyong1
    7. As you may have noticed, dear Samsung actually pasted the sticker on the embedded CPU in such a way that it covers a little of the CPU die. You may want to restick if yours exhibit the same issue.
    Removal of Hard Disk Drive and Battery
    8. Remove 4 screws (labelled 1 to 4 in orange)
    9. Disconnect the cable from the ZIF socket. (labelled 5 in green)
    10. Remove battery cable (labelled 6 in pink)
    11. Remove 2 screws securing the battery. (labelled 7 and 8 in pink)
    Reverse the process to reassemble the notebook.
    hohum likes this.
  4. yknyong1
  5. yknyong1
    Reserved for further 4
  6. thtvn
    thtvn Newbie
    Did you make it?
    Sent from BlackBerry using Tapatalk
  7. ButtersS
    ButtersS Notebook Enthusiast
    Rep points! Thanks yknyong1!!
  8. yknyong1
    Updated OP
  9. yknyong1
    Re-sized pics for faster loading times.
  10. aznguyen316
    aznguyen316 Rock Chalk Jayhawk
    Guide kicks major butt. Thanks a lot. I just got a NP700 and since the back cover was kind of a PITA to remove with all the tabs I did the SSD replacement, RAM and thermal paste. One question, is only one slot available and the other slot under the keyboard or something? I got the Best Buy model and it came with 6GB, the one I removed being a 2GB stick. I put in a 4gb module but would rather have both the same sticks...
