Samsung Recovery Solution III not working- Please Help!
Discussion in 'Samsung' started by chink182, Sep 11, 2010.
  1. chink182
    chink182 Newbie
    Please help me fix my computer, I have a Samsung N110.
    My computer needed to be recovered from a previous state. I tried to use Complete Restore on Recovery Solution III, but when I try to recover from the most recent backed-up state, a pop-up appears and says "Unable to insert an item". I tried to recover from the oldest state (initial computer setup) and the same thing appears. My backup is on the D: drive
    Now when I try to open up my computer it says "BOOTMGR is missing Press Ctrl+Alt+Del to restart" and if I restart it will just say this again over and over. I could not find anything online about this problem. Please help because I need this computer for some work purposes.
    Thanks!
  2. chink182
    chink182 Newbie
    Bump.
    Please help, I am pretty computer retarded, any advice or help would be appreciated!
  3. chink182
    chink182 Newbie
    Bump....nobody? =*(
  4. MelaTonin
    MelaTonin Newbie
    I know nada about your particular laptop recovery system, but if you have the OS disc, you could try to repair start-up?
    If you don't have an OS disc, you can find original ISOs of them easily enough. You would just need to set the BIOS to boot from disc in a notebook. But I guess this is a netbook, so I assume you would have to burn the ISO onto a USB pendrive (use the HP formatting tool) and set bios to boot from that. Then just select the 'Repair you computer' then 'Start-up repair' options.
    Worth a try. Someone else might have a better approach, though.
  5. KrazyKong
    KrazyKong Notebook Geek
    Mela, where would one find an ISO of the OS disc? I never got one with my Samsung Netbook and want one.
  6. John Ratsey
    Please wait 24 hours before bumping a thread.
    Your problem is not something specific to Samsung but means that Windows (which version?) has got its underwear tangled.
    Feed "BOOTMGR is missing" into Google and choose the hits relating to your version of Windows.
    John
  7. chink182
    chink182 Newbie
    Thanks for the responses! The reason I thought this might be specific to Samsung, is because the "BOOTMGR is missing" didn't happen until I tried to use the recovery program...which makes me believe that the recovery data is somehow corrupt. If that is the case, I am unsure what to do if I need to recover data in the future.
    I am contacting samsung, as all I have is the disc that came with the box, and I tried to use it to boot from BIOS and it doesn't work, so I am assuming it doesn't have Windows on it.
    My computer doesn't even work in safe mode, I've never had my computer unable to do that in my life!
  8. chink182
    chink182 Newbie
    Oh, and it's Windows XP, btw. I can't seem to find anyone with a Windows XP disc handy.
  9. John Ratsey
    You should be able to reinstall the factory image by pressing F4 when the BIOS screen is showing. See the Samsung guide. The full reinstallation will wipe everything on C: but the basic restore option might fix the Windows boot problem.
    John
  10. Pk77
    Pk77 Notebook Enthusiast
    Recovery Solution 4 it's compatible with your os/hw? If yes try to use that.
