SAMSUNG R480 keyboard HELP!!
Discussion in 'Samsung' started by nomorenick, Mar 16, 2010.
  1. nomorenick
    nomorenick Newbie
    Hi, i just bought Samsung R480 recently.
    was quite happy with this laptop until i started chatting with it. I found that the spacebar, when i press it, even though the buttom sinked in, sometime the space doesnt come out until i actually apply more pressure.
    Hence, wan to clarify with anyone owning this laptop, are you having this problem too? as in you press u spacebar softly til it sink in completely, does the space come out or does it only come out if u apply more pressure to it? Coz other button seems ok to me except the space bar.
    Thank you guys for helping in advance!!
  2. naton
    naton Notebook Virtuoso
    You may have something stuck underneath the space key cup... food or hair.
    They are few ways to clean a keyboard. Mine is to clean it with an old tooth brush. Turning the laptop upside down while typing on the keys should help remove anyting stuck underneath them.
  3. impruv
    impruv Notebook Evangelist
    or you could always use the air dusters and blow at the keyboard
  4. diego4321
    diego4321 Newbie
    I bought it yesterday,and i have a problem with this key. If you press the space bar inthe sides it doesnt work. It works if you pressit only inthe middle of the key and very hard
  5. John Ratsey
    Some keyboard problems clear themselves with a bit of use. Firmly push down the space bar at various positions along its length and then give it a bit of exercise for a few hours and see if the problem fixes itself. If not, contact either the retailer or Samsung technical support to report the problem. They should then give you an RMA number which will enable you to return the computer and get a replacement.
    John
  6. diego4321
    diego4321 Newbie
    sorry my english, but i dont use often
    I just cameback from the store and they verify the problem and they change it for another R480. I tun it on, one hour installing W7, and the same problem...the space bar sometimes doesnt work.
    For me its enough... Im going to returned again and going to get my cash...This keyboard sucks.
    John, you are problaby in the truth,but inArgentina I bought this computer for 1000 dol and im not going to used for hours until its start function properly. Its my first expirience with samsung and i guess its the last. 2 computers in 3 days and the same problem...
    If im going to buy a samsung im problably going to excercise my big toe finger next time.
  7. wc326
    wc326 Notebook Enthusiast
    i didn't have any problem with my samsung r480 tho...
  8. corky1
    corky1 Newbie
    I just bought the R480 i5 model with 14" lcd and I'm having the same problem with the spacebar not working properly. It works only 5% of the time the other 95% nada. Tried updating the software for synaptics pointing device and I still have the same problem. I've notice that they keyboard only works when pressing firmly on the center of the spacebar otherwise it doesn't work.
    Looks like i'm going to send it in for refund or exchange.
  9. csprings
    csprings Newbie
    About a month ago I made a post here about Samsung laptop (it's R530, not R480 though) that the spacebar wasn't working well. I exchanged the first one with another one of the same kind, and the spacebar was working all right until just a few days ago when the problem started again. I just have to press a bit harder to get it working (about 1 out of 10 times). I am a translator and a good keyboard is critical.
    I am afraid I will have to return this one too.
  10. Lemonjai
    Lemonjai Newbie
    I don't have the problem at all with the Samsung's keyboard and the spacebar wasn't any problem when I first got it. Has any one tried replacing the harddrive from the Samsung harddrive? I put in my black Scorpio from Western and it feels a bit slower then the 5400rpm Samsung drive =/ I check the score it rates it as 5.8 and Samsung one as 6.0 >_>
