Samsung BIOS Update Problems
Discussion in 'Samsung' started by John Ratsey, Nov 27, 2012.
  1. dyazbek
    dyazbek Notebook Enthusiast
    I can't suggest anything other than calling Samsung tech support at 1-800-726-7864. Please tell me what bios versions you updated from and to, because I just got a notification on my NP350E7C-A01US that a new BIOS version P08ABE is available for improved stability. If you updated to that version, I would be very hesitant to do to so.
  2. Dmrg
    Dmrg Newbie
    Probably because the bios update set something to the default value. Check in your bios, in the boot section, the value about the uefi/legacy SO and set it to uefi. Make sure to exit bios saving changes.
  3. tubbyrincewind
    tubbyrincewind Newbie
    I have just updated to this version (after a few days of waiting for Samsung's servers to let me get it). No issues other than I had to reactivate Windows 8 by phone.
  4. dyazbek
    I just updated from P07ABE to P08ABE with SW Update, after 7 days of trying, and it installed without a hitch.
  5. randomone1
    randomone1 Newbie
    Re Samsung Bios update problem
    Dear anyone,
    I have a 2009 NP-x360 and have just tried to update the bios to the variant currently on the samsung web site (run as an.exe from the desk top)
    seemed to go ok during the install, however windows 7 will no longer boot (gets to black start up screen with windows written on it) then crashes out of the process.
    bios will open up I have tried the reset to defaults option and save, does not change anything
    I have tried the automatic "let windows fix this for you to" to no result.
    I have tried to roll back to a previous system restore point to no result
    I am now out of good ideas, does anyone have a solution ?
    many thanks for any help you are able to offer.
  6. John Ratsey
    The disk access mode comes to mind. I think 2009 was in the era when the hardware was switching over from IDE to AHCI so there's a 50% chance that the default in your BIOS (and the upgrade automatically applies the defaults) isn't the same as what Windows was installed for. The result is that Windows starts, loads the wrong driver for the HDD and can then get no further because it can't read the disk.
    If it's not IDE/AHCI then it's another setting relating to the disk access mode. I recall the Windows on my Dell E6400 being pre-installed with drivers for both modes. Look through the BIOS setup and see what you can find.
    John
  7. randomone1
    randomone1 Newbie
    John,
    Many thanks for your help, I hunted round the bios but was unable to find any setting which got me further in on the original installation. however I tried a new clean install from a win dvd which booted from the bios as expected. The new clean installation worked, but I had to reinstall everything ! As always backups are king! I can only think that the bios updater corrupted something in the original windows installation preventing it booting.
    thanks again.
  8. sliyk
    sliyk Notebook Enthusiast
    hi everyone
    i have a smasung series 5 np530u3c
    yesterday i updated my bios using the sw update program after trying for many days, i think everything went fine but then it restarted and took me to the boot menu screen where is shows my hard drive but when i press enter nothing happens, i have tried tweaking with all the settings of the bios and i have also deleted and recreated my partitions and reinstalled windows 8 but to no avail
    the bios verion is P12AAJ
    micom version is P12AAJ
    is there is way i can reinstall this bios using ocmpand promt? because that about the only thing thats working on this machine, or can i download my bios
    really stressed cause its not working! :(
  9. John Ratsey
    See this thread for advice about how to downgrade the BIOS.
    However, I wonder if the cause is that the BIOS update changed some settings. See this post for some more trouble-shooting suggestions.
    John
  10. sliyk
    Thank for your reply John
    I have tried almost everything even the CMOS battery tweak but to no a ail my bios settings and like you want them to be I am posting a video of what my laptop is doing
    Samsung - YouTube
    Could this be from a partial or corrupt installation of the bios?
