Samsung 850 EVO 500GB for Aorus x7 v6?
Discussion in 'Gigabyte and Aorus' started by Cariblo, Apr 30, 2017.
  1. Cariblo
    Cariblo Notebook Consultant
    Ah so my normal HD is under that metal plate? Damn was so hoping to add the 2.5". Is it just as easy to add an M.2?
  2. MiSJAH
    MiSJAH Notebook Deity
    Super easy, dismantle as before, remove the solitary screw in an emtpy M.2 space, insert new M.2 PCIe SSD, hold down and replace screw.
    And swap the HDD for that 850 SATA SSD if you are keeping it ;)
  3. Cariblo
    Thanks :) and yeh would like to but its only 500GB and im already using most of my 1TB HD :(
    MiSJAH likes this.
  4. Cariblo
    Sorry one more question: I assume I have to format it like any new HD? This wont be replacing anything I just need more space on my pc
  5. MiSJAH
    That is correct.
  6. Cariblo
    Just to make this as idiot proof as possible (as i'm braindead with this type of stuff) is this where I insert an m.2? And when I receive the m.2 will it come with bits to screw it in?
    MiSJAH likes this.
  7. MiSJAH
    Yes, spot on. Remove the small silver screw with the marker pen mark on it.
    Cariblo likes this.
  8. Cariblo
    I've screwed it in and everything and gone to disk management but I can't seem to find it to format it. Have i missed a step?
    Edit: Its showing on Samsung Magician and in hardware just not in my computer and in disk management
  9. MiSJAH
    Odd, I'm not sure why it's not showing in Disk Management.
    Hopefully someone else can help.
    Edit: You have the Samsung driver installed?
  10. Cariblo
    No option seemed to come up for a driver. Do I need to go to the samsung website and find it? On the samsung magician program it says firmware version up to date does that mean anything?
    Edit: This is my disk management
    MiSJAH likes this.
